help buying trailer tires
Discussion in 'Towing' started by sskarr151, Jul 1, 2014.
  1. Jul 1, 2014 at 4:19 PM
    sskarr151
    sskarr151 [OP] Well-Known Member
    Scott
    Scottsville Va
    05 white sport
    3in Rough Country, Blacked badged
    i have a 18ft landscape trailer that is rated for 7000lbs. the cheap tires from tractor supply wear out way to fast. what tire would you all recommend. i dont want to break the bank, but want a good tire.
  2. Jul 2, 2014 at 10:31 AM
    F-125Racer
    F-125Racer Well-Known Member
    Arkansas
    09,DC,TRD Sport, 4WD, TRD S/C
    Goodyear Marathon. Run the biggest one you can fit, and go 10psi more air pressure than the sidewall says. The 10psi extra is right off of the Goodyear website.
  3. Jul 2, 2014 at 4:56 PM
    SilverGraphite
    SilverGraphite Expat Aussie
    California
    2011 TRD 4x4 bog standard
    Where is that on their website? I wasn't able to find it. Running tires over-pressure is the best way I know to cause a blowout!
  4. Jul 2, 2014 at 7:41 PM
    F-125Racer
    Arkansas
    https://www.tirerack.com/images/tires/goodyear/Marathon_Special_Trailer_Applications.pdf
    Actually, higher air pressure helps reduce tire temperature since the tire isn't flexing as much. Google Goodyear Marathon and you'll find plenty of reading on the subject. I tow several thousand miles per year and I've not had a single tire issue since I saw this bulletin and increased the pressure. Before that, I'd loose about a tire per year to tread separation. I'd check the temps at each gas stop with an IR gun and occasionally I'd catch one just before it blew as the temp would spike as it was starting to come apart. This is all very well documented on several RV sites.
    This bulletin has ben out for several years, even though it's dated 2014.
  5. Jul 2, 2014 at 7:44 PM
    Fiddy
    Fiddy Well-Known Member
    Justin
    Phoenix
    stock
    carlisle is always a decent brand
    or try going to a LT tire if you can fit them
  6. Jul 2, 2014 at 7:59 PM
    F-125Racer
    Arkansas
    I saw about the same thing with both Carlisle and Bridgestones, LT tires were worse, I went thru them very quickly. I might add I'm within 10% of max rated load on the Marathons, I travel at highway speeds most of the time, and most of my travel is in the summer.
  7. Jul 2, 2014 at 8:57 PM
    campthewestcoast
    campthewestcoast Oceanfisherman
    Napa, CA
    Power extend/retract towing mirrors,brake controller,30amp charging system for TT,snug top camper
    What rated sidewall are running in trailer tires? I think you should be running E rated Trailer tires, even if you have to change the rim size and stay away from china made trailer tires. I'm running D rated for my trailer( Maxxis 8008 ) tires but these are the most exspensive tires out there.
  8. Jul 3, 2014 at 1:16 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Don't buy your trailer tires at TSC, go to a local truck tire place, and they can get you special duty trailer tires.
  9. Jul 3, 2014 at 4:57 AM
    Spindifferent
    Spindifferent Well-Known Member
    Central Texas
    2013 PreRunner 4.0 v6
  10. Jul 3, 2014 at 10:24 AM
    SilverGraphite
    California
    Agree that higher air pressure within spec will help keep the tires cooler. But that PSB only says that IF you are going to run the tires overspeed (i.e. faster than 65mph) then you should increase pressure 10 psi based on the trailer placarded inflation. Nowhere does it say to go over the max pressure listed on the sidewall of the tire.
    I run Goodyear Marathons on a trailer loaded out to about 6500lbs (gross is 7000). I've put close to 30,000 miles over 7 years on it and am on my second set of tires. I run them at 5 psi under the max pressure listed on the sidewall and I've never had a tread separation or a blowout and the tread wear pattern is normal. On the other hand, I don't overspeed the tires either, 'cause it just kills my gas mileage.
    YMMV.
  11. Jul 3, 2014 at 5:08 PM
    AEmedic
    AEmedic Well-Known Member
    Boise, ID
    2014 DCLB 4X4 TRD Sport Supercharged
    TRD Supercharger, Toytec Adj. Coil-Overs, Bilstein 5100's, JL Audio system w/Kenwood DNX9980HD HU
    Last I read, Carlisle were Chinese tires, a good LT tire is the way I would go. Or buy the Maxxis 8008...
  12. Jul 14, 2014 at 3:08 PM
    taco206
    taco206 Well-Known Member
    I recently bought some Carlisle load range D 205-75-15 radials. Tires in this size are usually load range C and pump to 50 PSI and are bias ply. The carlisles I bought pump to 65 psi. They have been great so far. Look for them, they are the ones to get for sure. Don't get bias ply.
