help buying wheels (size)
Discussion in 'Wheels & Tires' started by Elliebarley1978, Nov 4, 2010.
  1. Nov 4, 2010 at 10:44 AM
    Elliebarley1978
    Elliebarley1978 [OP] Well-Known Member
    canada
    weathertech floor liners, wet okole fronts, leer 100xq cap, trd exhaust
    hi, im a little confused as per what size wheel i can put on my truck.
    wheel sizes are 17 x ___. does it matter what the second number is?
    the trd sport is 17 x 7.5
    im looking at a wheel that is 17 x8.5 is this going to be a problem?
    any info would be great. thanks
  2. Nov 4, 2010 at 11:01 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    8.5 is the width of the wheel, in inches. It determines what range of tire sizes you can run.
    What's far more important is the offset and/or backspacing of the wheel, and the bolt pattern.
  3. Nov 4, 2010 at 4:52 PM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    You want to be between 8 and 9 with 4.5 inch of backspacing.
  4. Nov 4, 2010 at 5:03 PM
    Elliebarley1978
    canada
    thanks
    so what is the optimum offset/ backspacing . i have some options.
    i m going to get a 17 inch wheel and i have 265/70/17 tires that i do not want to change out
  5. Nov 4, 2010 at 5:37 PM
    TexasTacoma37
    If you never plan on running 285's, then you can get rims with 4.5 to 5.5" backspacing. The 4.5 will stick out a litte further.
    If you want to run 285's some day, get the 4.5" backspacing.
    Backspacing is caclualted by using offset and rim width, btw. You can find conversion charts on google.
