Help bypassing the stock tweeters?
Discussion in 'Audio & Video' started by humbotaco, Feb 17, 2015.
  1. Feb 17, 2015 at 10:26 AM
    humbotaco
    humbotaco [OP] Active Member
    2015 TRD Off-Road AccessCab
    I've installed a 2 channel amp and some three way 6x9's in place of the factory woofers but I tapped into the stock wiring. So the new 6x9 speakers work when the tweeter is plugged in but not when the tweeter harness is unplugged. I'd like to bypass the tweeters without doing too much rewiring. Could I just pull the tweeter and connect the 4 tweeter side wires together so that there is still current through the stock tweeter harness that flows to the woofer wires?
  2. Feb 17, 2015 at 1:42 PM
    fizik
    fizik Accidental Offroader
    Minnesota
    '13 DCSB SR5, '10 DCSB TRD OffRoad (deceased)
    My understanding is that the 6x9s are wired in parallel with the tweeters on the tweeter side of the plug, so you can't just disconnect the plug. So, you just disconnect the tweeters at the tweeter, not the connector plug. You do not need to connect the tweeter wire (in fact, that might even be a bad idea). This is just from what I've read on the forums. I haven't taken a look at the wiring myself, but will be some day soon.
  3. Feb 18, 2015 at 10:12 AM
    humbotaco
    I wonder why it would be a bad idea to leave the tweeter connected? I'm now thinking of adding an aftermarket tweeter if i have to deal with that stupid harness. That stock tweeter/mid range is yucky
  4. Feb 18, 2015 at 1:48 PM
    fizik
    Minnesota
    No, I'm not saying you shouldn't leave the tweeter connected, I'm saying you shouldn't remove the tweeter and then connect the wires. Somewhere, on one of those wires is a capacitor used as a cheap crossover for the tweeter (to prevent the mid/low range signal from blowing out the tweeter). You don't want to accidentally wire that capacitor in parallel with your new speakers. If you don't want the tweeters, just clip the wires at the tweeter and tape them off.
    But like I said, I haven't removed my door panels yet to verify just exactly how it is wired.
  5. Feb 18, 2015 at 5:26 PM
    humbotaco
    Got it. Thanks.
  6. Feb 18, 2015 at 5:32 PM
    gearcruncher
    Canadain bumper technician
    Whats your tacoma ? year ,engine size and model ?
    If you put this information on the left side under your user name , you get quicker answers
  7. Feb 18, 2015 at 5:35 PM
    humbotaco
    Thanks for the tip. Doing that now
  8. Aug 30, 2019 at 6:54 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    So just to confirm. Leave the harness connected, but cut the wires to the actual tweeter. Is it really that simple?
  9. Aug 31, 2019 at 6:14 PM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    I would get the 4 pin adaptor and jumper the pins.
  10. Sep 3, 2019 at 6:43 AM
    CowboyTaco
    North Georgia
    11 TRD Sport
    That could work. That way, I can easily reinstall the OE tweeter if desired.
