HELP! Can -12 offset work on a 285/70/17 with a 2.5 in lift?
Discussion in 'Wheels & Tires' started by ChasingCoues, Nov 20, 2013.
  1. Nov 20, 2013 at 7:44 PM
    ChasingCoues
    ChasingCoues [OP] Member
    Arizona
    14 TRD Offroad
    I have Nitto Trail Grapplers, 285/75/17's with a 2.5 suspension lift. I got the Rockstar 2 wheels with a -12 offset, the performance shop said they would require to much trimming? Desert Rat said they could make it work, but I don't want to risk permanent damage. Would I be better off with some basic XD 17x9 with 0 offset?
  2. Nov 20, 2013 at 8:19 PM
    ChasingCoues
    Arizona
    14 TRD Offroad
    Very new to this stuff, any help would be appreciated!
  3. Nov 20, 2013 at 8:28 PM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    how wide are the wheels?
  4. Nov 21, 2013 at 6:00 AM
    ChasingCoues
    Arizona
    14 TRD Offroad
    Thanks for the reply! They are 17x9 with -12 offset. I think I may need something more like the XD 17x9 with 0 offset. Although, the people at Desert Rat think they can make them fit with lots of cutting.
  5. Nov 21, 2013 at 6:01 AM
    Large
    Large Red
    Why not have them install them before assuming you have to cut?
  6. Nov 21, 2013 at 6:17 AM
    ChasingCoues
    Arizona
    14 TRD Offroad
    The performance shop I brought them to, to do the lift and the install of the wheels and tires said that it would require to much cutting? They said I needed positive offsets on Tacomas, I was just wondering if anyone has had a different experience here. This is my first truck, so I am def learning some costly lessons.
  7. Nov 21, 2013 at 6:36 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Its only a 4.0 back spacing you should be fine just note trimming is required with 285's no matter what wheel you use. Anyone that tells you otherwise doesn't drive over anything more then a speed bump ;)
    Handes23 likes this.
  8. Nov 21, 2013 at 6:53 AM
    ChasingCoues
    Arizona
    14 TRD Offroad
    So I can make the -12 offset wheels work? It's just going to need some serious trimming?
  9. Nov 21, 2013 at 6:56 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    I would stay with the -12 offset which is 4.5bs but I would also go with a 285/70r17 versus a 285/75r17.
  10. Nov 21, 2013 at 7:05 AM
    Large
    Large Red
    He's right, that's a 34" tire.
  11. Nov 21, 2013 at 7:39 AM
    ChasingCoues
    Arizona
    14 TRD Offroad
    Sorry guys, I fat thumbed what I meant to type. They are 285/70/17 NOT 75's. With that in mind it seems you guys think it will work?
  12. Nov 21, 2013 at 7:44 AM
    BORNWILDGUY
    Rich
    Florida
    You will probably have to take the front mud flaps off and some miner trimming on the plastic. With the -12 offset you won't have to worry about the tire comining in contact with the uca.
  13. Nov 21, 2013 at 8:11 AM
    JLee
    Jerry
    Benicia, CA
    A 17x9" with a -12mm is a 4.0" BS
  14. Nov 21, 2013 at 9:06 AM
    BORNWILDGUY
    Rich
    Florida
  15. Nov 21, 2013 at 9:14 AM
    JLee
    Jerry
    Benicia, CA
    Well I guess wheels are measured different then normal math. 9" divided by 2 is 4.5" that would be a 0mm offset take away 12mm roughly 1/2" and you have a 4.0" BS :confused:
  16. Nov 21, 2013 at 5:35 PM
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
  17. Nov 21, 2013 at 5:46 PM
    BORNWILDGUY
    Rich
    Florida
    Fuel makes some kick ass wheels
  18. Nov 22, 2013 at 6:44 AM
    ChasingCoues
    Arizona
    14 TRD Offroad
    Thanks for all the replies gentleman, I ended up going with the 17x9 with 0 offset XD Black Crank. All they had to do was remove the front mud flaps, it fit like a glove!
  19. Nov 22, 2013 at 2:22 PM
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    What Brand/size rubber did you end up with...and have you flexed/stuffed the suspension any to checks for any rubs..
  20. Nov 22, 2013 at 7:03 PM
    Xer0 SiN
    Hilo, HI
    this and that...
    285s are gonna require you to remove the front mudflaps and minor cutting. when i was running my small icon lift (3.5"), i was running a set of 285s. needless to say, i had to take off the front flaps and had some minor trimming at the bottom of the fender flare. if houre going with a 2.5 or 3" lift im guessing youre goinf to have to cut more.
