Help. Can some one hook me up?
Discussion in 'Technical Chat' started by Bearskill, Jan 4, 2010.
  1. Jan 4, 2010 at 5:59 PM
    Bearskill
    Bearskill [OP] Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    So, long story short, I stripped out a break line on my 06 putting on extended lines on. Orderd new ones. They come in tomorrow. But the guy that was helping my has to work tomorrow. He and I did not plan on my truck being a two day thing. ANYWAYS....... Can some one that knows whats up give me a good run down about how to bleed my breaks? PLEASE!!!!!!!!!!:eek::eek::eek:
  2. Jan 4, 2010 at 6:28 PM
    Bearskill
    Sac
    Anyone? PLEASE! It wold mean the diffrence of getting my whip back tomorrow or Friday. Im begging here.
  3. Jan 4, 2010 at 6:31 PM
    Bearskill
    Sac
    I know it's a bad idea, but im half tempted to baby it to the dealer on E break alone. only about 10 blocks.
  4. Jan 4, 2010 at 7:49 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    Are they for the front or rear? If the stripped out line is on the front, you'll most likely wad your truck in to a pole, if you try to drive it on the e-brake.
    Try this site for the basics.
    http://www.popularmechanics.com/automotive/how_to/4213448.html
    Remember, you're just getting all the all the air out of the system. Take your time and do it right, it's not hard, and you can do it by yourself if need be.
  5. Jan 4, 2010 at 7:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    :proposetoast:
