Help - can't get steel wheel center caps on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VermontTaco, Nov 28, 2015.
  1. Nov 28, 2015 at 10:43 AM
    VermontTaco
    VermontTaco [OP] Well-Known Member
    Vermont
    2015 DCSB TRD Sport Silver
    Weather Techs Mats front and rear, Wet Okole seat covers, BakFlip Fibermax tonneau cover, Power Pop N' Lock, Flyzeye interior lights, Scangauge 2, IMMRYO Rearview mirror bracket, upgraded Homelink, temperature gauge, and compass rear view mirror, Matt Geko bed lights, OEM bed mat, Beerad's Antidark engine lights, interior LED lights, TRD SEMA 17" Wheels in gunmetal gray, LT265/70/17 BFG KO2 Load Range C, and center console/glove compartment organizers.
    TW - I need some help. I bought a set of steel wheels off CL for winter that came with center caps. I'm putting them in today, but I can't get the center caps to stay on. I've tried to use a rubber mallet to pound them on, but that doesn't work either. Any suggestions?
  2. Nov 28, 2015 at 11:14 AM
    OhDannyBoy
    OhDannyBoy Well-Known Member
    DFW’s Southern Star
    2015 4x4 DCSB SR5
    Do you have a McGard locking lug nut in place? The center cap won't clearance the "ring" around that sucker...remove that lug nut, then try.
  3. Nov 28, 2015 at 11:17 AM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    They won't stay on the wheel if its not mounted to the truck. They are meant for you to mount the wheel to the truck, then lightly tap them on
    TacoEspecial likes this.
  4. Nov 28, 2015 at 11:17 AM
    AR15xAR10
    They sandwich between the wheel hub opening and the hub
  5. Nov 28, 2015 at 11:44 AM
    AR15xAR10
    I set the wheel on the hub, hand tighten all the lug nuts, then tap the center cap on, THEN tighten them with the air gun.
    Then torque the lugs when the truck is back on the ground
  6. Nov 28, 2015 at 11:46 AM
    VermontTaco
    Vermont
    The lug nuts do not hold on the center caps, correct?
  7. Nov 28, 2015 at 11:46 AM
    AR15xAR10
    Correct. The metal tabs on the center cap sandwich between the hub and the wheel
    VermontTaco[OP] likes this.
  8. Nov 28, 2015 at 1:05 PM
    VermontTaco
    Vermont
    @AR15xAR10 thanks for the help. I was able to easily install the center caps once the wheels were in the truck. Appreciate the help.
    AR15xAR10 likes this.
  9. Nov 28, 2015 at 1:44 PM
    AR15xAR10
    No worries! Its what we're here for. Happy to help. :)
