help!!! cant get tie rod loose from knuckle
Discussion in 'Suspension' started by fftank76, Oct 16, 2009.
  1. Oct 16, 2009 at 7:00 PM
    fftank76
    fftank76 [OP] FIREFIGHTER
    TANK
    Texas
    2005 Tacoma Double cab
    right now i only got a rockford fosgate 12 thin line beind passenger seat got rockford fosgate class d 2000 watts pushin it i got swaybar removed 3 in lift 2 miniphantom lightbars whelen siren box and siren rod holders diff breather mod
    ok so i was working on my truck installing my spacer lift today when i ran into a problem after i removed the cotter pin and nut from the tierod i could not get it broke loose from the knuckle am i doing something wrong is there an easy way to do this sorry if there is a thread on this already but i didnt feel like searching through 106 threads
  2. Oct 16, 2009 at 7:11 PM
    fftank76
    TANK
    Texas
    its on my 07 prerunner in the instructions for the kit it says this
    Remove cotter pin from the outer tie rod end on the steering linkage. Using 19mm socket remove the nut. Using a
    hammer hit on the side of the cast knuckle to allow the tie rod end to separate from the knuckle. Remove the linkage​
    from the knuckle. Push linkage forward to make room for installation. Retain factory nut & cotter pin.
    and i cant figure out why they wont seperate....i wish i could get a pic up of what i am talking about.
  3. Oct 16, 2009 at 7:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Did you hit it with a hammer like instructed?
  4. Oct 16, 2009 at 7:20 PM
    fftank76
    TANK
    Texas
    yes but it did not budge and i didnt want to beet it to much and mess anything up but im not sure weather or not i was hitting in the right place
  5. Oct 16, 2009 at 7:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hit it in a different place.
  6. Oct 16, 2009 at 7:30 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Or you could always use a puller. This is the correct way to remove a tie rod end. Going cave man with it will usually work, but at the expense of damaged threads.
    You can get a full puller set at your local autoparts store (rented) for free. Just leave a deposit and you will get your money back when you return the tools.
  7. Oct 16, 2009 at 7:31 PM
    fftank76
    TANK
    Texas
    ok so i know this isnt exact but its close i cant get this peice to come loose any advice
    20090501-1043-P3QPT--Sportsmobile--Steering--Drag-Link--Steering-Arm--Ball-Joint--1.jpg
  8. Oct 16, 2009 at 7:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Go rent a puller.
  9. Oct 16, 2009 at 7:36 PM
    fftank76
    TANK
    Texas
    thanks for all the input i believe ill rent a puller also do u really need a strut compressor to put a spacer lift on i know these may seem like dumb questions to some but to me they are legitament questions i do not have the knowledge and would rather learn from others..
  10. Oct 16, 2009 at 7:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. You need a strut compressor. Dont use the cheap ones or you could hurt yourself. Use a wall mounted one, or similar.
  11. Oct 16, 2009 at 7:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    There is a rumor that they are under alot of pressure...Not sure if I belive it or not.....
  12. Oct 16, 2009 at 7:43 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Exactly--Hit it a few times with a heavy hammer. It'll come loose.
  13. Oct 18, 2009 at 4:54 PM
    dalsmthme
    dalsmthme Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
    Hitting it where the top arrow is will work, but it usually works better if you have someone pull down on the tie rod as you hit it. Just be careful not to hit the boot. It usually only takes a couple hits if someone is pulling down on the shaft.
  14. Oct 18, 2009 at 5:01 PM
    cheehab
    cheehab I bleed Black and Gold
    Adam
    Winter Park, CO
    2015 Tundra TRD Pro CrewMax
    I had this problem too and eventually cave-manned it apart with a BFH and a block of wood. It will come apart but it'll make for a pretty shitty and frustrating afternoon!
  15. Oct 19, 2009 at 7:05 PM
    fftank76
    TANK
    Texas
    ok so i got it off i didnt use a BFH i just hit it one good hard lick with a 3lb shop hammer and down she fell slo in regards to the strut compressor i got very curious after the first side and thought to myself F!!! it ill try it and found they are not under that much pressure so renting that strut compressor turned out to be a pain in my ass and wallet cause somewhere along the way my reciept i was suppose to show to get my refund disappeared so i am now the proud owner of a strut compressor....lol i will be posting pics of my build very soon i am waiting to pick up my tires wed afternoon!!!
  16. Oct 19, 2009 at 7:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Does the spacer you are installing mount to the top plate, or inside the coiil? I have a thumb that would disagree with them not being under too much pressure.
  17. Oct 20, 2009 at 10:28 PM
    sledbert
    sledbert Member
    British Columbia
    05 TRD 4x4
    In my past life I was a mechanic, here's what I can offer...
    Hit the side of the housing that the rod end goes through. hit it HARD, probably 3 or 4 times. I have used the "proper tool" but prefer this method. The tool also tends to damage the boot. The vertical part that the nut was on is tapered, when you hit the spindle you break the contact free. Partially from the imapct vibration & ever so slightly from the very slight distortion of the inner cone shape. This is reversed when reassembled.
    Yes the springs are under EXTREME presure when assembled, you MUST use a good compressor tool, if your spacer is designed to fit on the spring & under to top plate of the assemble. ALWAYS keep your head away from the end of the strut (just in case it slips or lets go when you're working on it)
    Unless like Chris mentioned, its a spacer that sits on top of the assembly
    hope this helps. :)
