HELP!! can't go into reverse
Discussion in 'Technical Chat' started by ryanringle, Aug 18, 2010.
  1. Aug 18, 2010 at 10:22 PM
    ryanringle
    ryanringle [OP] Active Member
    Chandler, AZ
    08 TRD 4x4
    Debadged Tinted Tails Moto Metal 951 265/75/16 Hankook dynapro atm
    I can't go into reverse in my 08 tacoma 4x4 trd offroad. When I put it into reverse, it goes back fine for one maybe two rotations of the wheels, and then the driver side front tire locks up. If i try to go farther in reverse, it just drags my tire. Then when I put it into drive, and turn the wheels a bit, the tire unlocks, and drives normally. What could it be?
  2. Aug 18, 2010 at 10:24 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    is the caliper loose???
  3. Aug 18, 2010 at 10:33 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    Are you sure 4x4 isn't on.
  4. Aug 18, 2010 at 10:43 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i can back up in 4wd...
  5. Aug 18, 2010 at 10:49 PM
    ryanringle
    Chandler, AZ
    08 TRD 4x4
    I thought of the 4wd thing, I went over to a dirt lot a little bit ago, engaged 4hi, and it locked in just fine. then i switched it into 2hi, and drove for a sec, and then put it into reverse. It did the same thing, front wheel locked up, and then wouldn't unlock when I drove straight. when i turned the wheel back and forth, it unlocked the front wheel just fine. I'm taking it to the dealership in the morning, its still under warranty. I just hope they don't say it's due to the bilstein 5100 lift in the front, or the larger than stock tires i have on it.
  6. Aug 18, 2010 at 10:51 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    The question is, did you get it used or new? It can be a few thing and no you can still move your truck in reverse if its in 4wd..... It can be your gears in your diff might be stripped or you might have your reverse gear striped in your tranny. Your hub bearing might have dirt in it if you went wheeling somewhere. If i were you, just bring it to a shop and let them diagnose the problem for you IMO if i were you i wouldn't try to fix it yourself if its a gearing problem.
