Help! Can't separate transmission from engine!
Discussion in '1st Gen. Tacomas (1995-2004)' started by shampoop, Feb 14, 2012.
  1. Feb 14, 2012 at 1:33 AM
    shampoop
    shampoop [OP] Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    In the middle of a clutch job on my 03 v6 4x4 5spd, finally got everything taken care of, now my trans won't separate from the engine! I really am at a loss, I've removed all 6 bellhousing bolts and completely removed the starter. My truck is a little rusty on some parts, but nothing crazy. I've tried changing the weight distribution of the trans on the trans jack, and have changed the angle a million times trying to seperate everything but have had zero luck.
    Any suggestions?
  2. Feb 14, 2012 at 8:46 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    First I would double and triple check that all of the bolts are removed. Since you said you pulled 6 bolts then you likey already did that, but it's worth looking again.
    IIRC, I had to hit the bellhousing with a hammer to get them to sebarate when I did my clutch a year ago. I used a block over it though in order not to dent the transmission. Also make sure you're pulling straight back and down slightly, which I found difficult to do since I did mine sans vehicle lift.
  3. Feb 14, 2012 at 10:47 AM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    Probably corroded around a dowel and causing them to stick together. Concentrate penetrating oil around the dowel(s), tap the area with a hammer, grab the trans by the tail and shake the hell out of it. If your not moving the engine on the mounts then you're not shaking it hard enough.
    cruxofthebisquit likes this.
  4. Feb 14, 2012 at 10:59 AM
    Codystauffer
    Codystauffer We are insignificantly importnant in this universe
    Cody
    California
    97 V6 4x4 Super White
    3" Revtek Spacers in the the front, AAL in rear, Random custom painting, stereo system, cb.. more
    When i had trouble removing my tranny, it was because there was some sneaky little bolts in random places. When i finally had all of them removed. It was still stuck, so my buddy and just hit it with a hammer and shook it like hell, until she slipped loose and knocked me in the noggin haha.
    Kens04Taco likes this.
  5. Feb 14, 2012 at 12:26 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    This^
    PB Blaster, and a dead blow hammer or block of wood and normal hammer. Last one I did got free of the dowels but hung on the input shaft. Lots of shaking later, it was out.
    Keep your noggin clear:p
  6. Feb 14, 2012 at 12:36 PM
    slo13zx3
    slo13zx3 Well-Known Member
    Brian
    forest city pa
    14 trd off 6speed nav
    if the clutch is still hooked up try pushing it in real fast it helps on big trucks
  7. Feb 14, 2012 at 12:36 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    My father owned a Transmission shop for 40 years, and i spent the better part of child hood there helping. You may have heard of it was called AAMCO!!
    Anyway, beat on that sucker with the largest plastic mallet and shake the shit out of the output shaft, it will come loose. Someone above mentioned the dowel pins, more than likely it is those dudes that got you held up. Seriously, giver hell, you wont hurt anything unless you drop it off the lift. :D
  8. Feb 14, 2012 at 1:18 PM
    jeepdude
    jeepdude Regular Member
    Jesse
    Connecticut
    2004 ext cab 4x4 TRD, bone stock for now
    don't whack it with ballpeen...use a rubber hammer. I've had luck with the stomp on the clutch trick too
  9. Feb 14, 2012 at 4:49 PM
    JSFoster75
    JSFoster75 Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    If at first you don't succeed, get a bigger hammer... ;)
  10. Feb 14, 2012 at 5:43 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Sounds like your just hung up on the pins/dowels Dont be afraid to get a thin bladed screwdriver or punch & a mallet & aggressively "tap" the end of it & start a small "wedging" in a couple spots between trans & engine/bell housing it'll make seperating a snap. Keep in mind also that the output shaft of trans is fairly long but I dont think its caught up in the pilot bushing...;)
  11. Feb 14, 2012 at 6:30 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Get a prybar between the motor and the trans, pry and it will seperate, but pry a little 180 degrees from each other so it wont bind. And also go and step on the clutch pedal a couple of times, that tries to spit them too.
  12. Feb 14, 2012 at 11:21 PM
    shampoop
    southwest WA
    HOLY SHIT I FINALLY GOT IT!!!
    That was by far the most difficult single task I've ever done. That shit was really really really stuck on there. I'm not some tiny weak dude either. I'm a lean 180lbs and pretty athletic. I shook that shit soooooo hard for hours and nothin. Finally what I think made the difference for me was prying underneath by through the hole left by the inspection plate on the bottom. Then lots of penetrating oil and rotating between prying at 2 terribly obstructed locations, shaking the shit out of it, raising and lowering the trans jack, prying, shaking, etc. The shaking/pulling didn't seem to do anything really until towards the end when the prying had done 80+% of the job.
    My clutch/pressure plate actually look better than I expected. Since shortly after I bought the truck about 2 years ago, the clutch started getting super grabby and resisted ANY slipping. At first it was only when cold and/or wet, then eventually got to the point where it was all of the time and recently got really bad.
    Really close to the rivets, but not quite :)
    Flywheel lookin HOT!
    Pressure plate too.
    Thanks for all the help guys.
    4WALKER and wilcam47 like this.
  13. Feb 15, 2012 at 4:27 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Make sure you get the flywheel resurfaced and inspected.
  14. Feb 15, 2012 at 10:13 PM
    shampoop
    southwest WA
    lol, for sure, already did. Looking at everything I think the heat checking was the main cause of the issues.
  15. Feb 16, 2012 at 7:43 AM
    RattleTractor
    Harry
    VT
    What clutch did you get?
    When I did mine I went with OEM because they're proven to last and I get the Toyota tech pricing so it wasn't too expensive. But I would get the Marlin Crawler HD kit if I were to do it again.
  16. Feb 16, 2012 at 8:38 PM
    shampoop
    southwest WA
    exedy OE
  17. Feb 17, 2012 at 11:08 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    The heat checking is a symptom, not a cause. When the clutch starts slipping, it overheats and glazes the friction pads. The blue marks on the pressure plate and flywheel were the hot spots.
    Hopefully, you had a good machinist to fix the flywheel.
  18. Feb 17, 2012 at 9:04 PM
    shampoop
    southwest WA
    That's the weird thing. I NEVER felt the clutch slip. Not even a little bit. It was really grabby/choppy when engaging, but never slipped when engaged and hitting the gas pedal.
  19. Feb 19, 2012 at 6:37 PM
    96Taco
    96Taco Well-Known Member
    Alberta
    2014 DBL CAB Tacoma
    I have the same problem. it feels grabby when releasing it.
    Let me know if changing the clutch fixed it
  20. Feb 22, 2012 at 12:54 AM
    shampoop
    southwest WA
    Yea, mine would grab so hard it would just try to stall the truck instantly.
    After the new clutch and resurfaced flywheel it drives like a million bucks! :cool:
