Help, car won't start
Discussion in 'New Members' started by Taco928, Sep 22, 2012.
  1. Sep 22, 2012 at 10:55 PM
    Taco928
    Taco928 [OP] New Member
    Yuma Arizona
    98 Toyota Tacoma Prerunner 2.7l
    Stock
    My pickup needs to be jump start everytime I want to turn it on. At first I thought it was the battery so I went to autozone and the guy checked it there. He said it was no good. I bought a new battery and the truck drain the new battery. Than they told me might be an alternator or starter and I went ahead and checked those. Nothing wrong with that. So now what else can be causing my battery to be drain everytime I turn on my truck.
  2. Sep 22, 2012 at 11:33 PM
    Dcpsychobilly
    Dcpsychobilly Well-Known Member
    Aurora Colorado
    04 dbl cab Taco
    Bumpers, skids, lights and more lights, trail gear bumper, sliders, front kings, dakar lift leaf springs rear, corbeau seats
    Just because they say its good doesn't mean it is, do you have some sort of volt meter?.
    Check current battery voltage (should be around 12 volts)
    Check battery voltage when truck is on (voltage should be higher showing alternator is charging it)
    Check to see voltage when its off (to see if something is draining your battery while its off)
    If you do not have a voltmeter what I think is the easiest thing to do is disconnect your battery when you turn it off (after driving because if you alternator isgood your battery should be charged) leave your truck alone (with battery disconnected) come back later connect it....
    If it starts your alternator did its job and.charged before your disconnected it (which should happen, it should start no jump needed)
    If it does not start your alternator isn't charging or something in the charging system is not right.
    This is to check if you have something draining your battery and if your alternator is good (charging system)
    Thats where I would start all in my opinion. I hope this helps lmk if I can be of any help
  3. Sep 22, 2012 at 11:41 PM
    Dcpsychobilly
    Aurora Colorado
    04 dbl cab Taco
    O and you shoulda posted in the appropriate place
    (For future reference)
    And hi welcome to Tacoma World lol
  4. Sep 23, 2012 at 3:51 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Please see Section 17 and 10 in the Car and Deep Cycle Battery FAQ on www.batteryfaq.org.
  5. Sep 23, 2012 at 3:51 AM
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Please see Sections 17 and 10 in the Car and Deep Cycle Battery FAQ on www.batteryfaq.org.
  6. Sep 23, 2012 at 4:14 AM
    Artillery68
    Artillery68 Well-Known Member
    Bob
    Gloucester Co., N.J.
    2012 DCSB Super White Sport
    Rugged Cover tonneau, In channel vent visors, Hose clamp tailgate mod, Pop-N-Lock, Fog lights anytime, de- badged/removed graphics, TRD shift knob, OEM bed mat, trimmed all 4 mud flaps, LEDs in
    Welcome from N.J. :wave:
