Help, changed oil filter housing(aluminum) and now leaking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rajman, Jan 1, 2020.
  1. Jan 1, 2020 at 2:37 PM
    Rajman
    Rajman [OP] Member
    Raj
    2017 Quicksand TRD Offroad
    None yet
  2. Jan 1, 2020 at 2:47 PM
    Clearwater Bill
    Billy
    Largo Florida
    Seems to have a couple of possibilities.
    Flawed part
    or
    Flawed installation
    I'd certainly 'start over' by examining the part and double checking my installation before showing up at a dealer.
  3. Jan 1, 2020 at 2:50 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Does it leak at the point where it attaches to the engine, or from the drain port at the bottom? In either case, the most likely scenario is that the o-ring was damaged during installation. Pull the housing off, examine the o-ring from the effected area and replace if necessary. If the o-ring isn't the culprit, look for damage to the threads, or sign of defective casting. I have one of those on mine, and it doesn't leak a drop.
  4. Jan 1, 2020 at 2:51 PM
    vwarwar
    vwarwar Member
    Vitor
    Tacoma 19
    Did you put the o-ring?
  5. Jan 1, 2020 at 2:59 PM
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    And did you oil the o-rings?
    wilcam47, over60, Hoff and 2 others like this.
  6. Jan 1, 2020 at 3:36 PM
    Barcared
    Barcared Well-Known Member
    Philadelphia, PA
    2016 Barcelona Red TRDOR RIP. 2020 MGM TRD OR.
    and is O-ring in the right groove? and is the valve on the bottom used to evacuate the oil in the filter tightened as well?
    Scotty61, HP11, CaptainBart45 and 3 others like this.
  7. Jan 1, 2020 at 3:52 PM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    The aluminum cap is machined on the loose side in order to make it less compatible with housings intended for plastic caps. Sometimes they work, sometimes they leak.
    Rajman[OP], kahanabob and skiploder like this.
  8. Jan 1, 2020 at 3:53 PM
    Rajman
    Rajman [OP] Member
    Raj
    None yet
    Yes, oiled the oring, maybe I should take it off, use new ring and try again?
    Valve tightened, leak coming from housing .
  9. Jan 1, 2020 at 3:57 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    If all else fails go back to the plastic one
    skiploder likes this.
  10. Jan 1, 2020 at 6:26 PM
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    No! No! No! No!
    The forum gurus who whine about bruised shins, dry eyeballs and humongous rear seat headrests said this was a must do mod that is foolproof.....no one said it would leak and no one mentioned that Toyota phased this part out because of galling concerns.
    Then again, most of these guys also bitched non stop on how hard it was to find the correct drain plug, can’t read the dipstick and argue incessantly over which oil is best.
    Sorry, gotta run. Need to chime in on a thread about how to use the gear lockout. We just logged the third post of the day from someone who thinks it’s a sport shifter.
  11. Jan 1, 2020 at 6:46 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    you are not the first person to post up same issue.
    Rajman[OP] likes this.
  12. Jan 1, 2020 at 6:54 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    I have 2 of those. One on wife Camry and 1 on my taco before I went to Baxter conversion. Never a leak from any of them. Have the one from mine in the garage as spare just in case.
    jetfishn and GreyBaldTaco like this.
  13. Jan 1, 2020 at 7:03 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    My neighbor broke his on his Camry using a breaker bar (trying to loosen it from a previous oil change from a local garage). It was a Sunday and he came to me panicking, completely unaware they were available aftermarket. I drove him to Autozone and we picked up a metal Dorman for $30. 20 minutes later all was good.
    The fitment was perfect and the quality was excellent. Zero leaks.
    https://m.autozone.com/collision-body-parts-and-hardware/oil-filter-cover/toyota/camry
  14. Jan 1, 2020 at 7:19 PM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Retro fit a legacy Toyota aluminum oil filter housing to fix a problem that doesn't exist...and now you have a real problem. What was wrong with the OEM housing?
    No worries, there is a simple fix. Put the superior OEM housing back on. There are a number of morons who trash it simply because in their peanut brain, a weak ass die cast aluminum part is better than a high strength polymer part.
  15. Jan 1, 2020 at 7:38 PM
    Rajman
    Rajman [OP] Member
    Raj
    None yet
    Seems to make sense that the aluminum would be stronger man but obviously it is not the same fit.
    Addendum to story. I was not able to get the plastic housing loose after valvoline boys says that it was too tight. In the end I had to chisel it loose before the tool that fits over the housing could turn it.
    Going to the dealer in the morning to get the plastic housing and new seal.
    Thanks everyone for your quick responses. That's the beauty of this forum.
  16. Jan 1, 2020 at 7:40 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    X2, there is nothing wrong with the Factory plastic housing.
  17. Jan 1, 2020 at 7:43 PM
    Hoff
    Hoff Well-Known Member
    I have no issues with the OEM one. Just don’t over tighten it. Needs a little more than hand tightness
    Vmax540, hfjeff, Tacoma1845 and 2 others like this.
  18. Jan 1, 2020 at 7:50 PM
    Plain Jane Taco
    USA
    These things are sealed by an o-ring not a gasket. There is no reason to torque these housings down. I light snug is all that's required
  19. Jan 1, 2020 at 8:10 PM
    TnTuna
    TnTuna Well-Known Member
    3rd Gen Tacoma
    The OEM filter box will show you exactly where to place the O rings. Best of luck.
  20. Jan 1, 2020 at 8:21 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I have thought about the aluminum unit but haven't bothered. The composite one works and as long as it always installed properly with a torque wrench and the threads are lubricated before install it will he fine for years.
    The o-ring is the sealing device, not the threads. If there is no damage to the housing like a crack or gouge, then the o-ring is damaged or incorrectly sized for the unit.
    Edit: When torquing I use an appropriately sized torque wrench. I use a ⅜ drive wrench that maxes out at 75 lbsft , not my ½ drive one that it maxes at 250 lbsft.
