HELP..Changed Plugs, 4wd light blinking and wont engage..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KevLot17, Sep 25, 2011.
  1. Sep 25, 2011 at 11:33 AM
    KevLot17
    KevLot17 [OP] Well-Known Member
    Kevin
    Pennsylvania
    '10 Blacked Out TRD Sport
    Debadged, Toytec Ultimate Lift, Banks Monster Exhaust, AFE Pro Dry filter, Black Grillecraft grille, Flat Black background headlights, Red Blinkers and markers with alternating turn signal mod, Krypton Bulbs 6000K Headlights and Fogs, Fog Light anytime Mod, LED interior lights with map light mod, AVS Black Taillight Covers, Tinted Windows, WeatherTech Digital floor liners.
    So i just changed my plugs, im mechanically inclined so i know i didnt mess anything up... i got all plugs done, started it up and noticed the 4wd light blinking... tried putting it in 4H (then went forward and reverse a few times in the driveway) and it wont engage.. what could have happened? the only thing ive tried to fix it was disconnecting the battery for 10 minutes, no luck... can anyone help me out???
  2. Sep 25, 2011 at 11:59 AM
    Large
    Large Red
    Dumb question, but are you moving forward or reverse at least a little while it's trying to engage?
  3. Sep 25, 2011 at 12:00 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    did you turn the steering wheel as well?
  4. Sep 25, 2011 at 12:06 PM
    KevLot17
    Kevin
    Pennsylvania
    Yes i was moving back and forth and i took it for a ride and its still blinking
  5. Sep 25, 2011 at 12:08 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    is your foot on the brake and the clutch? (6spd)
  6. Sep 25, 2011 at 12:16 PM
    saugus
    saugus Well-Known Member
    Don't have 4x4 but is there any wires for it above or around the plugs? I know I had to disconnect a switch and a couple of hoses when I did mine.
  7. Sep 25, 2011 at 12:36 PM
    KevLot17
    Kevin
    Pennsylvania
    Yeah i disconnected 1 hose but put it back on
  8. Sep 26, 2011 at 6:12 AM
    reg boulette
    reg boulette Well-Known Member
    Just changed my plugs (V-6) (thanks Chris 4X4!) and had to remove a lot more than one hose to get at driver's side. Maybe you knocked a wiring connection loose or a wire parted?
  9. Sep 26, 2011 at 6:19 AM
    KevLot17
    Kevin
    Pennsylvania
    I used the same write up... it was kind of a pain goin in between and around the fuel lines and such, but with a long enough extension its possibe (because i did it) on the drivers side i removed the one hose that has the squeeze type clamp andpushed it back towards the firewall and out of the way, then i removed that black metal brace... that is it. and i looked over every thing countless times, as did my 2 mechanic buddies that showed up in process:notsure:..... thats why im gonna go with the 'Its a coincidence that it just happened to come on after i did the plugs' Takin it to dealer Wednesday... hopefully theyll finger it out..:frusty:..
  10. Sep 26, 2011 at 6:47 AM
    Wally
    Wally Well-Known Member
    Ontario (the metric version)
    07 Access Cab TRD 4x4 6MT 1GR-FE
    I'm not sure what you referenced for the procedure, but is sounds like you didn't disconnect any wiring connectors.
    Assuming you know the proper procedure to engage/dis-engage 4WD on your truck, the only logical conclusion would be that you pulled on one of the connectors "somewhere" hard enough to cause a signal break.
    So, either a entire connector is loose enough that one or more pins aren't seating correctly or you pulled on an individual wire hard enough to disengage a pin in a connector. It sounds like you had to push some things out of the way hard enough that you may have inadvertently applied more force to a segment of the wiring harness than you realized and there is a signal break somewhere. A false "send" is much more unlikely, as well as the scenario of a failure elsewhere at exactly the same time as your plug change procedure.
    The cheapest remedy involves a little labour ... look at all the connectors in the vicinity of the procedure and re-seat them, disassembling all required components for proper access. If that doesn't work, take them apart, inspect the pins and if they look good, re-assemble. If that doesn't work, take it to the dealer for diagnosis at $100@hr ...
    It all depends on how patient and persistant you are.
  11. Sep 26, 2011 at 6:59 AM
    KevLot17
    Kevin
    Pennsylvania
    The only connectors that i disconnected were the coil harnesses.. The only thing i pushed out of the way was 2 fuel lines and the evap hose. The only other thing i could think of is maybe somehow i pulled a vacuum line off down below when i moved fuel lines... But i cant find anything..
  12. Sep 28, 2011 at 3:17 PM
    Wally
    Today's Wednesday ... did you figure out what it was? I'm always curious what the root cause of a problem is.
  13. Sep 28, 2011 at 6:17 PM
    KevLot17
    Kevin
    Pennsylvania
    Ok guys sorry it took so long i got home and passed out, so the guy said my system was out of time, one ofthe actuator pins was engaged while the other wasnt(causing the vibe) all they had to do was reset the 4wd(somehow) and it works like a charm now wit no vibes!! And didnt cost me or Toyota a penny... I could not be happier:D
  14. Sep 28, 2011 at 7:44 PM
    saugus
    GJ;)
  15. Dec 21, 2013 at 6:54 AM
    cookee62
    cookee62 Well-Known Member
    Lake Mary, FL
    06 DBL Cab
    URD SS, URD Y-Pipe, DTLT Headers, 3" URD Cat Back, Fox 2.5 CO, TC UCA, Fox Rear Resi, SS brake Lines, All pro 1.5" leafs, Halo Projector Headlights, WE Bead-lock Rims, 33 BFG AT, No Sway Bar
    Im Having the sdame probelm.... Where would I find out whob to reset the 4wd?
