HELP Changing drums and axles in rear assy for ABS in axle swap HELP
Discussion in 'Technical Chat' started by bparham, Jun 21, 2010.
  1. Jun 21, 2010 at 10:30 AM
    bparham
    bparham [OP] Active Member
    SoCal
    03 Non-Pre
    3" spindle lift, power bass extreme speakers and tweeters, pioneer deck, kicker sub, 2000 W speaker amp, 3600 W sub amp, weather gaurds, DT headers, Gibson exhaust, URD short shifter, URD CAI, URD/Volcom/Electric/Sexy_Eyes Decals, window tint, Viper Alarm system
    I have an 03 base taco and i am swapping in a 4x4 rear axle assy with 410 gearing. but the new axle doesnt have ABS while my stock rear axle assy does. Can I swap just the drums? or do I have to swap the drums and axle shafts? Or what do I do?
    Is there a write up on this?
    Thannks
  2. Jun 21, 2010 at 11:41 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I am pretty sure you need to swap axle shafts too. pretty much whole axle assembly that bolts to housing. I believe the abs axle shafts have larger flat area for a ABS ring. You may want to put new seals while you doing that.
