Help, changing wheels and tires after Toytech 3" lift will this wheels/tires be ok
Discussion in 'Wheels & Tires' started by Jav S, Oct 25, 2010.
  1. Oct 25, 2010 at 11:48 AM
    Jav S
    Jav S [OP] Well-Known Member
    Montverde, Fl
    2010 DC TRD
    The lift is a Toytech ultimate lift for TSB, and the wheels are Moto Metal 0951 17x9 4.5 back spacing with BFG TA KO 285-70-17 wheels 2 yrs old and tires with 5k on them. (local seller) Will this set up work? These wheels where on a Chevy 2500 (update, I think these wheels are 8 lugs. I will double check darrrrrrrrrrrrrrrrrrrrrrn)....
    or should I keep my Dick Cepek 17x9 6-5.5, 4.5 back spacing and -12 offset and get same tires? of Nitto Dune grapplers?
  2. Oct 25, 2010 at 11:55 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Look like 8-lug to me.....
    Also the hub bore on chevy's is smaller than Toyotas, so if they are hub-centric, you would need to get them bored out.
  3. Oct 25, 2010 at 2:14 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    If they came off of a chevy 2500, then they are definitely 8-lug. You can also see in the pic that they are 8-lug.
  4. Oct 25, 2010 at 3:10 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    I say keep the wheels you have, and snag some new tires (Duratrac's?!?)... those DC's are nice!
  5. Oct 25, 2010 at 8:05 PM
    Jav S
    Montverde, Fl
    2010 DC TRD
    you guys r right. I noticed that while I was loading the photos (8 lugs). the guy did not put it on his add. Oh well i guess new set of shoes r on their way.
    Now which tires should I be looking at, no mudding, light dirt, sand and fire roads,
    1. BFG All Terrain TA KO
    2. Goodyear Wrangler Duratrac
    3. Nitto Terra grappler
    4. Nitto Dune grappler
    any suggestions will be appreciated. Thanks for the inputs.
  6. Oct 25, 2010 at 8:15 PM
    jaw154
    jaw154 Well-Known Member
    Jared
    CA
    2016 Quicksand TRD Off road
    Soon...
    Do you have a bakflip g2?
  7. Oct 25, 2010 at 8:22 PM
    Jav S
    Montverde, Fl
    2010 DC TRD
    yes I do, and i love it.
  8. Oct 25, 2010 at 9:03 PM
    jaw154
    Jared
    CA
    Soon...
    Is it pretty waterproof?
    I just got mine on last week and i too love it but it rained here and let in a ton of water. so that was very discouraging
  9. Oct 25, 2010 at 9:26 PM
    Jav S
    Montverde, Fl
    2010 DC TRD
    did u install the 2 drain hoses that came with the cover? mine are about 1/2" thick that I had to drain through the bed? mine dosen't leak. well very little if any.
  10. Oct 26, 2010 at 2:30 PM
    jaw154
    Jared
    CA
    Soon...
    I didnt install it myself, the trruck cover place i went to did and they have the drain hoses but water leaks in from the corners. im thinking they might not have installed it right.
