Help.. Check light, why?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vivica89, Jan 6, 2010.
  1. Jan 6, 2010 at 6:29 PM
    efmugen
    efmugen Well-Known Member
    Los Angeles,CA
    1996 Tacoma Single Cab
    FYI autozone and pep boys charges for that service now....
  2. Jan 6, 2010 at 7:13 PM
    vivica89
    vivica89 [OP] Well-Known Member
    Los Angeles, CA
    '06 TRD PreRunner Double Cab
    I called and AutoZone does charge, but Pep Boys by my house does not.
  3. Jan 6, 2010 at 7:15 PM
    vivica89
    Los Angeles, CA
    Thanks for the info though.
  4. Jan 6, 2010 at 7:59 PM
    efmugen
    Los Angeles,CA
    coo.... good luck
  5. Jan 6, 2010 at 8:16 PM
    vivica89
    Los Angeles, CA
    I just went to Pep Boys, they ran the code and it is T1094. Thanks
  6. Jan 6, 2010 at 8:18 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Hey i think we should put list that in the diy part im going to pm a mod
  7. Jan 6, 2010 at 8:19 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    agreed ktm
    vivica...are you sure thats the code that came back?
    im not finding any results for any codes with a T prefix
  8. Jan 6, 2010 at 8:20 PM
    vivica89
    Los Angeles, CA
    I called and verified if it was a "T" or "P" and he said it was a "T" as in Toyota.
  9. Jan 6, 2010 at 8:23 PM
    JimBeam
    JB
    2015 Tundra
    strange
    that list i posted earlier is a pretty complete list of OBDII error codes with the bottom ones being Toyota specific...which also still start with P
    i hope someone else can help because im at a loss
    every which way i tried googling either brought me back garbage or trucks which had T1094 as the stock number at a dealership
    personal opinion is that he misread the code somehow
  10. Jan 6, 2010 at 8:25 PM
    vivica89
    Los Angeles, CA
    I also googled and nothing that starts with a T. I will try again. Thank you!
  11. Jan 6, 2010 at 8:28 PM
    JimBeam
    JB
    2015 Tundra
    try taking it to another autoparts place in the morning and get someone else to run the code to verify
  12. Jan 6, 2010 at 9:01 PM
    vivica89
    Los Angeles, CA
    I just went to Pep Boys, they ran the code and it is T1094. Is this the right code? I did verify if it was a "T" or "P". Thanks
  13. Jan 7, 2010 at 6:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I never heard of a "T" for a code.....They did it wrong. What issue are you having?
    MTopp likes this.
  14. Jul 19, 2010 at 9:55 PM
    SupTACO
    SupTACO New Member
    05 Taco SuperCharge
    TRD SuperCharger
    I have a 2005 Tacoma w/ TRD SuperCharge OBD-2 code is p0138 and p0157
    Prior to that I had p0156 Changed O2 sensors and cleared the codes.
    After O2 sensors had been replaced new codes p0138 and p0157 came up, I changed the MAF Sensor prosseding w/ clearing of codes.
    It seamed all was good but instead of coming on after driving 80 mile it delaid to 140 miles.
    Next was air filter which I found to be a 1/4 inch thick in dust. Having cleared the codes and after cleaning air filter I used an additive to clean the injector and intake manifold. Drove for 180 mile no codes no problem but latter got p0158 I tried the same prossedure over and now get the current OBD-2 codes p0138 and p0157.
    I'm not finding any fuel leaks, one thing that has me in dought is the fuel pressure regulator one end of the vacume hose had come off and burned / melted on the exhaust manifold, that was my first fix I made prior to the O2 sensors.
    Any Help Thank You.
  15. Oct 13, 2010 at 1:31 PM
    #35
    UndeadGames
    UndeadGames New Member
  16. Oct 13, 2010 at 1:35 PM
    #36
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    Holy thread revival :eek:
  17. Jun 6, 2011 at 1:11 PM
    #37
    mshane06
    mshane06 Member
    Shane
    El Centro, CA
    96 Tacoma LX
    My 96 tacoma keeps throwing out a P0171. There are no vacuum leaks, the Cat is ok, i replaced the O2 sensors, and i cleaned the MAF but the code still keeps coming back. i Dont know what else to do except take it to a mechanic and let him take my money....any help would be greatly appreciated
  18. Jun 6, 2011 at 1:41 PM
    #38
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Chipmunks chewing through the knock sensor wire harness will throw a CEL and mess up the auto tranny so it doesn't shift into overdrive. Not a cheap fix either. Ask me how I know?
  19. Jun 6, 2011 at 1:47 PM
    #39
    mjohn617
    mjohn617 Well-Known Member
    Petaluma, CA
    05 DC TRD sprt silver
    Haha...not doing it...can't make me!
    That was pretty funny tigerfan00, ill save everyone the grief and leave the quotes behind....post #9 FTW.
    EDIT:
    FUCK!!! January 2010
  20. May 29, 2012 at 8:34 AM
    #40
    katrina
    katrina New Member
    tony
    wrightsville pa
    01 tacoma
    how do i change the camshaft position sensor on a 3.7 2001 tacoma?
