Help cleaning wheels.
Discussion in 'Detailing' started by JONNY TACO, Mar 14, 2012.
  1. Mar 14, 2012 at 2:07 PM
    JONNY TACO
    JONNY TACO [OP] Well-Known Member
    PA.
    DARK METALLIC GRAY -DOUBLE CAB SHORT BED
    ADVANTAGE TONNEAU COVER,TOYOTA BED LINER, POP&LOCK TAILGATE LOCK, SIDE TUBES, WIFE IN PASSENGER SEAT
    What do you guys use to help clean the rims on a 2009 Tacoma. I have the 6 lug set up. I need something to clean betwen the thick " supports" .
  2. Mar 14, 2012 at 2:08 PM
    jlvhrse
    jlvhrse Well-Known Member
    Jen
    SoCal SGV
    2009 TRD Sport 4X4 Long Bed
    LSK front and rear LT and stuff
    I use a large soft brush with a no scrub wheel cleaner, works very well
  3. Mar 14, 2012 at 2:10 PM
    seksilumpia
    seksilumpia Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    if youre really picky,take off the wheel and clean it with the green scotch pad
  4. Mar 14, 2012 at 4:18 PM
    JONNY TACO
    PA.
    Good idea, but too much work for me.
  5. Mar 14, 2012 at 4:19 PM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    Nothing more than soap and water
  6. Mar 14, 2012 at 4:26 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    Wheel brush and soap and water.
    Never mind... :cheers:
  7. Mar 14, 2012 at 4:27 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Like scratching the clear coat?
  8. Mar 14, 2012 at 4:28 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Rob
    Pacific Northwest
    2018 TRD OR DCSB
    "Meguiars all wheel cleaner" (or similar) and a flexible wheel brush so you can clean the inside of the rim without taking the wheels off.
  9. Mar 14, 2012 at 11:20 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    x2
  10. Mar 15, 2012 at 5:29 AM
    JONNY TACO
    PA.
    thanks for the help
  11. Mar 15, 2012 at 5:51 AM
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | Access Roll-up Tonneau Cover, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat ---------------------------- | INTERIOR | Flyzeye V2W (Amber/White/Amber) Audio: Alpine CDA-117, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
    Yep, soap & water... I also wax my wheels and that makes for easy clean up.
  12. Mar 15, 2012 at 6:04 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    Ditto.
  13. Mar 15, 2012 at 6:22 AM
    1998tacomaowner
    1998tacomaowner Well-Known Member
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    sos pads on my old chrome rims still use them on my aluminum ones
  14. Mar 15, 2012 at 12:12 PM
    Gooch
    Orange County CA
    Chrome is harder than steel and goes relatively unscathed from steel wool.
    Most aluminum wheels are clearcoated (acrylic-urethane paint) which will gradually be removed by using steel wool.
    If your aluminum wheels are simply polished aluminim and not clearcoated, steel wool doesn't do much harm except that they will not be as shiny as if they were polished with a high-quality polish.
    Clearcoated wheels should be treated just like body panels as far as cleaning and protection goes.
  15. Mar 15, 2012 at 12:27 PM
    JONNY TACO
    PA.
    The sections where the grit layed is now rough to the touch and I can't seem to remove the grit.
  16. Mar 15, 2012 at 12:28 PM
    toyotatacomaTRD
    Rob
    Pacific Northwest
    2018 TRD OR DCSB
    You'll need a wheel cleaner to loosen that up.
  17. Mar 15, 2012 at 4:25 PM
    JONNY TACO
    PA.
    OK any suggestions as to which works best?
  18. Mar 15, 2012 at 5:29 PM
    toyotatacomaTRD
    Rob
    Pacific Northwest
    2018 TRD OR DCSB
    LOL.
  19. Mar 15, 2012 at 6:03 PM
    JONNY TACO
    PA.
    Tried it. It didn't remove the grit. That's why I asked again.
  20. Mar 15, 2012 at 7:18 PM
    toyotatacomaTRD
    Rob
    Pacific Northwest
    2018 TRD OR DCSB
    Any pics? I am wondering if your wheels may be pitted... PA is known for using harsh road salt that eats away the clear coat. Anytime I have used the Meguiars, it has removed everything pretty easily.
    In my State, they switched from road salt to something a little less harsh a few years back. It makes a big difference and still removes the ice from the roads.
