Help complete my lift
Discussion in 'Suspension' started by RiverBoyTRD, Feb 24, 2013.
  1. Feb 24, 2013 at 3:01 PM
    RiverBoyTRD
    RiverBoyTRD [OP] Well-Known Member
    Jonathan
    San Antonio
    05 TRD OR
    2 Hellas, 3 inch, spiders, grill guard, 285's, BHLM etc.
    As of right now I have procomp front struts and 2 inch blocks. My return hits the bank this week and I'm using it to finish my components. I know I need UCA's but after much reading idk what I'm doing, did many lifts never had to worry about them. For the rear I will be ordering a bolt flip and most likely ordering leaves, again reading and too many out there.
    I'm shooing for 3-4ish lift. I do off road occasionally it being beach runs, trails, very rarely mud....very rarely. I do use the bed and pull trailers from time to time. I do have adjustable gas shocks made for 2-3 lift so I'm thinking limit straps should be fine as I'm a finesse guy instead of balls to the wall.
    LR has a group buy now so input is welcomed, and alcans is the only leaves I really ever heard about.
    I will be getting $2300ish back and anything left over will be going towards tires. Thank you Tacos!!!!!
  2. Feb 24, 2013 at 4:06 PM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    How about a complete OME lift with 885 coils and Dakars in the rear? Add the LR or other UCA to top it off. That will get you up there solidly and be in your budget with money left over.
  3. Feb 24, 2013 at 4:19 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    ^ this. Also what would you need limit straps for?
  4. Feb 24, 2013 at 4:33 PM
    RiverBoyTRD
    Jonathan
    San Antonio
    05 TRD OR
    I already have the front coils. So the OMEs are not needed.
    I guess I'm asking which UCAs to go with, as I understand they are needed for alignment purposes? The straps would help keep the shocks from over extending, not super worried about it but cheap insurance is nice.
  5. Feb 24, 2013 at 4:34 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    There a bunch of companies that make UCA it is all about how much you want to spend
  6. Feb 24, 2013 at 4:35 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    and whether you want a uniball or a booted balljoint
  7. Feb 24, 2013 at 4:37 PM
    blake5995
    Blake
    Truckee, CA
    O yes i forgot about this aswell. ball joint is less expensive than a uniball.
  8. Feb 24, 2013 at 4:39 PM
    RiverBoyTRD
    Jonathan
    San Antonio
    05 TRD OR
    Is there advantages with one over the other?
  9. Feb 24, 2013 at 4:40 PM
    OZ-T
    Peter North
    British Columbia
    Uniballs offer more articulation , where the booted ball joint is more protected for winter salt etc
  10. Feb 24, 2013 at 4:41 PM
    blake5995
    Blake
    Truckee, CA
    Uniball is a open system allowing stuff to get into the joint. were as the booted balljoint is covered hence the name booted and doesnt get as much stuff inside.
  11. Feb 24, 2013 at 4:45 PM
    RiverBoyTRD
    Jonathan
    San Antonio
    05 TRD OR
    So I'm guessing boots is what I need, I don't need a ton of articulation. Be more worried of sand and dirt from my ranch than anything else.
    As far as leaves, are the Dakar leaves custom made like alcans? I was planning on ordering at least a 7 leaf pack from alcan.
  12. Feb 24, 2013 at 4:47 PM
    blake5995
    Blake
    Truckee, CA
    7 is a lot of leaves that is crazy what do you haul?
  13. Feb 24, 2013 at 4:49 PM
    OZ-T
    Peter North
    British Columbia
    I chose the LR UCA's because they wre less expensive and I was more concerned with getting a good alignment and having the ball joint more protected due to my winter conditions versus a need for greater articulation
    It should be noted you can get uniballs with SS balls
    Dakars are 7 leaf
  14. Feb 24, 2013 at 4:49 PM
    RiverBoyTRD
    Jonathan
    San Antonio
    05 TRD OR
    I prefer the ride of thinner leaves, had good luck on my f350 with a 12 leaf pack on the rear. I was able to get a smooth progressive ride.
  15. Feb 24, 2013 at 4:50 PM
    OZ-T
    Peter North
    British Columbia
    Daks are 7 leaf
  16. Feb 24, 2013 at 4:51 PM
    RiverBoyTRD
    Jonathan
    San Antonio
    05 TRD OR
    Any complaint from LR? The group deal isn't to shabby
  17. Feb 24, 2013 at 4:54 PM
    OZ-T
    Peter North
    British Columbia
    I haven't heard any complaints from LR :notsure:
  18. Feb 24, 2013 at 5:14 PM
    RiverBoyTRD
    Jonathan
    San Antonio
    05 TRD OR
    Good deal man thanks for the input, no reason to spend a nice penny if it isn't needed.
    Now deciding on bumpers :confused:
