Help correcting my suspension upgrade
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Karaquante, Jan 3, 2020.
  1. Jan 3, 2020 at 11:26 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Did you tighten the UCA while the truck was still lifted or after it was in the ground? Just a thought but you can over tighten it to a point where it sits too high and rises like shit. Would sit on the outside like you described. Try loosening the main UCA bolt and let it settle and then tighten. Should be able to do to without jacking up the truck if you can get a wrench in there. Not uncommon for folks to miss that step on installs.
  2. Jan 5, 2020 at 6:14 PM
    Karaquante
    Karaquante [OP] Member
    2006 Super white DCSB
    A thing or two
    Thanks for the thought nudavinci. I got it right when I put them in originally but Toyota maybe screwed that up when they changed the coils from the 886 to the 887. I’ll check it out.
    Thanks again
  3. Jan 5, 2020 at 9:33 PM
    nudavinci64
    Robert
    Sure thing worth a look or at least peace of mind.
  4. Jan 6, 2020 at 4:43 AM
    12taco12
    12taco12 Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    that sounds like your spring seat is upside down. i have 5100 and 886 at first setting and pelfrey steel bumper and settled around 3"
