***HELP!!!*** CRAWLBOX PART NEEDED!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HomerTaco, Oct 5, 2015.
  1. Oct 5, 2015 at 4:59 PM
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    I've spoken with literally everyone that is associated with manufacturing and installing this type of mod for our trucks - this is not something I can just get off a shelf there are non available until late October.
    NEED: OIL SEAL HOUSING for 6speed +05 Tacoma trans to crawlbox coupler.
    This is the WRONG part:
    Posting this in the off chance that someone has this and is not going to do the install for a while...
    I can overnight the replacement back as soon as I receive it.
    Snowballs chance in hell that someone's in this situation but I figured what the hell...
    Thank you!
    ~ Craig
  2. Oct 5, 2015 at 5:04 PM
    Pigpen
    Dan
    Northwest Montana
    Good luck, Homey... This sounds like a terrible situation to be in.
  3. Oct 5, 2015 at 5:22 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Not the end of the world but it puts everything back over three weeks at least if I can't get the piece by this Friday.
    Truck is immobile without it.
  4. Oct 5, 2015 at 7:33 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    Here's a bump hoping someone here can help you out.
    HomerTaco[OP] likes this.
  5. Oct 5, 2015 at 7:40 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  6. Oct 5, 2015 at 8:11 PM
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    Try RST?
  7. Oct 5, 2015 at 8:22 PM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
  8. Oct 5, 2015 at 8:39 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    I'm not even sure what that is! But I'll provide an extra bump anyhow.
    Good luck!!
  9. Oct 6, 2015 at 11:19 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Spoke with lowrange, inchworm, marlin, rocksolidtoys, and all-pro.
    No one has a spare.
  10. Oct 6, 2015 at 2:36 PM
    Gaunt596
    Matthew
    Central Maryland
    Darn, id send ya one if i had it. Also another free bump, somebody has this part
  11. Oct 6, 2015 at 2:40 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    not all-pro. spoke with John the owner today. he's got some for an auto trans but not manual.
    Sent an email to Sean, the owner of LowRange off road to see if he could get me in touch with the fabricator to expedite one or get me specs to have one made.
  12. Oct 7, 2015 at 7:13 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I'm having the part manufactured. Fortunately Wyatt was able to provide the specs for me. :yay:
    G.T. likes this.
