help! cv, front differential problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by houndogger, Sep 15, 2010.
  1. Sep 15, 2010 at 7:15 PM
    houndogger
    houndogger [OP] New Member
    Utah
    04 standard
    OK, I bought a 2004 tacoma 4x4 last week and it was hammered! The front differential was leaking gear oil like the deepwater horizon so I figured i'd pull the front axle off and change the leaky seal. The first bit was pretty simple, took off the tire, brakes, rotor, dust cover, cotter pin, axle bolt, pulled off the upper control arm... and the axle came right out. However I am stuck trying to get the cv housing off the differential.
    the seal I'm trying to get to is between the cv housing and the differential on the drivers side, but can't get the last bit off. If there is a c clip or something i just cant find it.
    I will post a couple pictures of what Im trying to get off if I have the wrong name.
  2. Sep 15, 2010 at 7:27 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    welcome to tw.
    use a big flat head screwdriver...or a good stout flat end pry bar and pop it outta there. go behind the flat spot on the stuck piece...between it and the diff.
  3. Sep 15, 2010 at 7:31 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  4. Sep 15, 2010 at 7:41 PM
    houndogger
    Utah
    04 standard
    I pounded a punch in there and wrenched on that but it wouldn't give, i figured there was a clip or something, i guess i'll need to cheater up on it. Thanks a bunch guys this gives me confidence to really wrench on it.
    also another thing i found really weird, the cv house spins freely i can turn it with my hand even when the transfer case was in 4 low, is this normal? i thought it was a constant velocity axle and thus would be locked if the transfer case was engaged. the passenger side is locked, but maybe only because the tire is still on the ground?
    it could be possible something is broken in the differential if this is not normal. i just bought the truck and never put the four wheel to the test.
    thank you so much!
  5. Sep 16, 2010 at 3:18 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Yep, just like the others said, just put in a large screwdriver or pry bar between the cv housing and the diff and give it a good wack. The c-clip that holds it in is actually inside and is basically just a friction clip. A good pop on it should cause it to come right out.
    As far as the one side turning freely, its an open diff, not a locked diff, so I believe what you're experiencing is normal. You'd have to install a locker to make both front wheels spin (or not spin) at the same rate.
  6. Sep 16, 2010 at 4:53 AM
    trd7
    trd7 4wd tacoma
    Tyler
    Columbia, SC
    95.5 Tacoma 4x4 4cyl auto
    AEM air intake
  7. Sep 16, 2010 at 5:00 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Spot on. You are spinning the spider gears.
