Help! CV joining with wheel hub broke camping
Discussion in 'Canada' started by Yukon DoIt, May 22, 2021.
  1. May 23, 2021 at 3:44 PM
    #61
    Taco-Obsessed
    @theesotericone any theories of what lead to this cv failure? Now I'm curious.
  2. May 23, 2021 at 3:47 PM
    #62
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Without knowing what the OP was doing when it snapped it's hard to say for sure. That grease does look old and dry so it could just be it's time in use.
    Taco-Obsessed[QUOTED] likes this.
  3. May 23, 2021 at 3:53 PM
    #63
    Yukon DoIt
    Yukon DoIt [OP] Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    Why it happened. Well, I am pretty sure my CV Boot was bad. I noticed it was leaking on one of my trips underneath the truck, didn't think too much of it. I also hit a pretty good hole in the gravel road. Thinking it was a combination of these that wore out and broke the cage and freed the assembly.
    The previous owner did have recurring CV problems so I will probably go OEM. Does anyone have a good source for oem online?
  4. May 23, 2021 at 3:57 PM
    #64
    eon_blue
    Azusa, CA
    I don't know if Toyota sells OEM remans for 2nd gens like they (used to) for 1st gens...reman units are far less expensive than new. I would try and stick with OEM though. Or CVJ since they also sell rebuilt OEM axles.
    If the boot was leaking grease that's what killed it. Once the grease is gone and/or dirt, water and debris gets into joint it's a time bomb
    Taco-Obsessed likes this.
  5. May 23, 2021 at 3:57 PM
    #65
    Taco-Obsessed
    That would make sense, and be the best scenario.
    The CVJ axles are rebuilt OEM. They are just as good as new OEM and cheaper.
  6. May 23, 2021 at 3:58 PM
    #66
    eon_blue
    Azusa, CA
    I can also attest to the importance of the axle nut on 4wd vehicles...I cross threaded mine once and naively thought it was fine until next time, 500 miles later my wheel bearing failed on my way up to my wedding one weekend lol. About lost my brakes on the highway as a result, luckily the wheel didn't come off. Was able to pull into a shop in time.
    That was a very expensive lesson on top of an already very expensive weekend
    Yukon DoIt[OP] likes this.
  7. May 23, 2021 at 5:54 PM
    #67
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    You still alive op?
  8. May 23, 2021 at 8:23 PM
    #68
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Just got home. 166 miles later I'm still alive. Haven't been under the truck yet to look at it. Gonna order some parts and drive the 4runner in the meantime.
  9. May 23, 2021 at 8:41 PM
    #69
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Almost didn't attempt it but then @zippsub9 stopped thinking with his beer can...
    Jokes though. Thanks everyone for the information and I'll update the thread with any new developments/carnage shots.
