Help! Dakar Leaf Install Question
Discussion in 'Suspension' started by BVCOTaco, Jan 20, 2012.
  1. Jan 20, 2012 at 9:53 AM
    BVCOTaco
    BVCOTaco [OP] Well-Known Member
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    I am working on installing my OME lift kit. I got the front installed last night, but I ran into a few issues while trying to get the leafs installed. The forward bolts on the existing leafs will not be coming off without cutting them.:mad: Does anyone know what size bolts those are? I assume they need to be grade 8?
    Also the new Dakars are labeled 'A' and 'B'. The 'A' is the drivers side?
    I did some searching, but am at work and don't have the time to read all the different threads to find that info.
    I am sure other have had this issue, so hopefully someone can chime in!
  2. Jan 20, 2012 at 11:05 AM
    BRONSON
    BRONSON Member
    Canada
    2009 TRD Sport DCLB
    A driver, B passenger.
    Not sure about the bolts.
  3. Jan 20, 2012 at 11:09 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Yeah, I had the same problem. We cut the bolts and went to the hardware store for new grade 8 bolts. I can't remember the size now though.
  4. Jan 20, 2012 at 11:17 AM
    Brunes
    Brunes abides.
    Rotorhead
    SO maybe I have older springs- but where did you find the A or B?? Cause I don't see any such markings on mine...so are the older versions not side specific??
  5. Jan 20, 2012 at 11:29 AM
    BVCOTaco
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    Brunes, The 'A' and 'B' are in the part number that is stamped on the leaf spring itself. When I searched before the install I remember someone saying that is fixes the sideways lean that a lot of Tacoma's have. Not sure if that is true or not though.
    I guess I will just have to cut the bolt apart and then figure out what I need. I live in a small town, so hopefully they have that size at our local hardware store!
  6. Jan 20, 2012 at 11:32 AM
    kmok
    Kyle
    Columbus, Ohio
    There's a code or whatever and at the end of the code there's A and B. I put mine on the wrong side and had bad taco lean :eek: When I swapped them to the correct sides it did help with the taco lean.
    X2
    If I remember correctly, it's the old bushing in your stock leaf pack that causes theses problems. Good luck!
  7. Jan 20, 2012 at 11:34 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Where's the overloads on the bottom 2 ?
  8. Jan 20, 2012 at 11:35 AM
    kmok
    Kyle
    Columbus, Ohio
    Not sure lol, I just grabbed this pic off of google images as an example
  9. Jan 20, 2012 at 11:36 AM
    BRONSON
    BRONSON Member
    Canada
    2009 TRD Sport DCLB
  10. Jan 20, 2012 at 11:51 AM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah...That isn't on my springs....So now I'm nervous about putting them in...
  11. Jan 20, 2012 at 11:57 AM
    BVCOTaco
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
  12. Jan 20, 2012 at 11:58 AM
    OZ-T
    Peter North
    British Columbia
    Mine didn't have the A or B either
  13. Jan 20, 2012 at 11:59 AM
    Brunes
    Brunes abides.
    Rotorhead
    Now I feel better. They hopefully go in tonight....
  14. Jan 20, 2012 at 12:03 PM
    BVCOTaco
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    Maybe it is just a 1st Gen thing???
  15. Jan 20, 2012 at 12:06 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    measure the arch... the one that has more arch will go on the driver side
  16. Jan 20, 2012 at 12:09 PM
    Shiftytaco
    Shiftytaco Well-Known Member
    Joey
    Mesa, Arizona
    Work in Progress
    I have Dakars on my second gen...no A or B on mine either.
  17. Jan 20, 2012 at 12:20 PM
    BVCOTaco
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    I was able to order the M14x1.5 x 100 grade 8 metric bolts from my local Napa store and they will have them in tomorrow morning! Can't wait to finish the install!
  18. Jan 20, 2012 at 12:21 PM
    OZ-T
    Peter North
    British Columbia
    Mine were the same
  19. Jan 20, 2012 at 12:45 PM
    Brunes
    Brunes abides.
    Rotorhead
    I would agree with this.
  20. Jan 20, 2012 at 2:32 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    The photo posted earlier is not a photo of Tacoma springs. They are an older style OME spring for what I think is a Land Cruiser. The front springs (bottom two in that photo) have no overload leaf. The top two springs are the rear springs that have an overload.
