Help, Damn squeaking noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by .Trdtaco315., Apr 23, 2010.
  1. Apr 23, 2010 at 3:13 PM
    .Trdtaco315.
    .Trdtaco315. [OP] Well-Known Member
    Will
    Santa ana
    03 Trd SR5 Prerunner
    ughhh i got this noise, its a squeaking noise when i accelerate to about, 30. then it comes back right before i stop.(and i mean like RIGHT before)
    i check front and rear brakes, and clean off with brake cleaner. im almost 99% sure its not in the diff. got any help? well thanks for ur time guys
  2. Apr 23, 2010 at 6:41 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Grease the hell out of your drive line & any other place you see a zirk fitting, sounds like you may have an extremely dry "U" joint, does the sound you hear , maybe sound like a piece of wire wrapped around your drive shaft ? If so, bad U-joint (or 2)...good luck......:cool:
  3. Apr 23, 2010 at 7:04 PM
    .Trdtaco315.
    Will
    Santa ana
    welll thank u for your posit after 15 people have viewed it haha.
    expensive to fix? or can i just grease/ lube everywhere.
  4. Apr 23, 2010 at 7:20 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    I had a chevy that did the same thing. Drove me nuts for about a week till I finally figured out it was the U-Joints. Mine were shot, hopefully you can just grease yours and it'll be good.
  5. Apr 23, 2010 at 8:18 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Try getting everything lubed up real good before doing /buying anything first. As far as expense goes, it varies: IF you need a U joint or 2. not sure but I'd say that $20-$25 each is ballpark. IF its the carrier (center support) bearing I just priced one & I was kinda shocked at the $128.00 sticker price attached to this little ,non servicable gem. But lube everything up first & goodluck .....:D:cool::D
  6. Apr 23, 2010 at 8:48 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    Mine had squaking noises coming the spring or whatever but i pressured wash it and it's gone! :)
  7. Apr 23, 2010 at 11:05 PM
    .Trdtaco315.
    Will
    Santa ana
    mines more of a rotating squeak, so yeah i got check those u joints
  8. Apr 24, 2010 at 12:20 AM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    I had a kind of the same problem. Check the Vaccum lines.
