Help! Day time running lights won’t turn off….
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kpatt9, Sep 20, 2022.
  1. Sep 20, 2022 at 11:24 AM
    Kpatt9
    Kpatt9 [OP] Well-Known Member
    Kade
    SLC, UT
    2013 DCSB
    Hi everyone. My day time running lights won’t turn off…. Even when the car is turned off and the key is pulled from the ignition.
    this all started after I disconnected the negative terminals on the batteries (dual battery set up) to reset my ECU. All lights and everything else works, kind of stumped on this one…. I do have an accessory/electrical board in the engine that was professionally done.
    any ideas?
    will post pics when I get home from work.
    Gunshot-6A likes this.
  2. Sep 20, 2022 at 11:41 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Easy check: Try bumping the little rubber plunger in the door jam. May be a stuck door open sensor.
    Oddity check: Is your trailer harness intact? I remember an old tundra thread where they had a similar / same issue and it was related to a damaged trailer plug harness.
    Next step: start pulling and reinserting relays + fuses related to the DRLs in case something is stuck open (relays)
    I'll update if I can think of anything else.
    Kpatt9[QUOTED][OP] and ginseng27 like this.
  3. Sep 21, 2022 at 8:14 PM
    Kpatt9
    Kade
    SLC, UT
    2013 DCSB
    I haven’t updated my bio but bought a first Gen.
  4. Sep 21, 2022 at 8:15 PM
    Kpatt9
    Kade
    SLC, UT
    2013 DCSB
    I pulled the fuse for DRLs so for now they are off… neighbors were calling and knocking on the door twice a night….. so at least they’re off.
