HELP! dealer reset ECU -now gas mileage is poor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hot2na, Jul 29, 2014.
  1. Jul 29, 2014 at 3:22 AM
    Hot2na
    Hot2na [OP] Well-Known Member
    Like the title says -there was some kind of recall on my 2012 AC that required a reflash of the ECU ...I was getting 20 mpg avg before that ...now I am lucky to get 15mpg average..E-mails to the service advisor at the dealer have not been returned...I dont think they know what to do about it...
    any suggestions ? ideas ? etc...
  2. Jul 29, 2014 at 3:56 AM
    Large
    Large Red
    Give it 1k miles or so then reevaluate
  3. Jul 29, 2014 at 3:58 AM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    that reflash is for the vsc system that has nothing to do with mpg
  4. Jul 29, 2014 at 8:10 AM
    Robman
    Robman Well-Known Member
    Rob
    Hawaii
    '14 Tacoma Double Cab
    Perhaps if he lost 1 or 2 mpg, but 5mpg is a 25 percent drop. I think the answer is in the title, take it back to the dealer.
  5. Jul 30, 2014 at 2:26 AM
    Hot2na
    its been 4 tanks of gas so far and it is improving slightly...got 17.5 @ fillup yesterday
  6. Jul 30, 2014 at 3:36 AM
    Blacktaco2042
    wisconsin
    i work at a dealer and i know what recall they did. they reflashed the vsc system
  7. Jul 30, 2014 at 3:52 AM
    MSCOFF
    MSCOFF Well-Known Member
    Mark
    CT
    2017 SR5 AC 4WD
    did they check and possibly lower the tire pressure while they had the truck?
  8. Jul 30, 2014 at 4:10 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    When you reflash the system, the vehicle has to relearn and adjust fuel/air ratios and such. This takes a little time. When I worked at Hyundai, we had recalls and TSBs requiring reflashes. It was a conversation I've had with customers thousands of times over the years. Shame on them for not telling you what to expect.
    Have you noticed higher/lower revving, different accelerator response, shift points, etc?
  9. Jul 30, 2014 at 10:25 AM
    Hot2na
    Just more sluggish response on acceleration....
  10. Jul 30, 2014 at 2:51 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    You burned 4 tanks in 1 day?!?
  11. Jul 30, 2014 at 2:55 PM
    Hot2na
    "You burned 4 tanks in 1 day?!? "
    no this has been going on a while...like 6 wks now
  12. Jul 30, 2014 at 2:58 PM
    File IFR
    Central MA
  13. Feb 23, 2015 at 1:14 PM
    Sparkler
    Sparkler Jedi
    So. Cal.
    2011 Tacoma 4x4, 4cyl.
    Did anything ever happen? Did it resolve itself?
  14. Feb 23, 2015 at 1:28 PM
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    Since this is the case, should I have the dealer reflash my truck since I put a header on my 2.7??
  15. Feb 24, 2015 at 4:01 AM
    Hot2na
    my mpgs finally recovered to 20...but it took a LONG time.....your choice...
  16. Feb 24, 2015 at 8:41 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    they wont reflash for a header upgrade.
