Help deciding kit - ome or king
Discussion in 'Suspension' started by Dmwood1984, Jan 20, 2018.
  1. Jan 20, 2018 at 3:57 PM
    Dmwood1984
    Dmwood1984 [OP] Well-Known Member
    New Jersey
    2018 Cement TRD Off-Road Double Cab Long Bed Premium Package with Options
    not sure if these two particular kits have ever been compared but what would you guys go with.. I know Everyone usually swears by kings.. both kits seem like great kits. Anyone know which will give me the biggest lift ? I also want no problems, noises, etc.. Also which ones ride quality will be closest to a stock trd off-road..
    these were taken from toytecs site
    OMETAC16BP51B - Old Man Emu BP51 Suspension Kit Lift Kit For 2005+ Tacoma
    Or
    KSTAC05 - King Complete Kit for 05+Tacoma
  2. Jan 20, 2018 at 3:59 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Subd for results -- maybe edit the post to put in a poll.
  3. Jan 20, 2018 at 4:04 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Camry or E class?
    Taco Addiction and dan0mite like this.
  4. Jan 20, 2018 at 4:04 PM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    How so? Both are resi setups, both have compression adjustment, only OME has rebound.....he didn't say what he was planning for a leaf pack if going with Kings....
    Reasonably similar I would say....certainly same ball park price wise.
  5. Jan 20, 2018 at 4:05 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Kings will give you as much lift as your crank
  6. Jan 20, 2018 at 4:49 PM
    kbp810
    kbp810 Well-Known Member
    Au Gres, MI
    2016 Tacoma TRD OR
    How do you plan on using the truck?
    The OME BP51 has the advantage of the compression and rebound adjustments - but the bypass systems means you're also only truly getting a 2.0 shock in a 2.5 shock body.
    With the King you are getting true 2.5 shocks. Larger piston means potentially longer shock life, and can withstand a little more abuse.
    For what it's worth - I'm certainly intrigued and tempted by the BP51's myself, but if it was my choice between those two, I would go with the Kings without even giving it a second thought. King vs Fox vs ADS would be a closer comparison.
    Dmwood1984[OP] likes this.
  7. Jan 20, 2018 at 4:59 PM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    Install the best and don't look back: Kings.
  8. Jan 20, 2018 at 8:41 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Subd for similar comparisons
  9. Jan 20, 2018 at 8:45 PM
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    I have old man emu but I'm definitely considering going to King for a better ride quality. The only thing is the rebuild requirement.. I put on about 30k miles yearly and don't have another vehicle to use while that's being done, so I'm not sure.
    I will say, if you go with Total Chaos upper control arms and it's anything like my experience, they will drive you insane. Mine are obnoxiously loud and no amount of TLC seems to fix it.
  10. Jan 20, 2018 at 9:08 PM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    Lol Camry is a practical car at best. No luxury no pizazz . Absolutely a point A to point B car with zero emotional attachment for owner .
    Camry says “ I just want reliable transportation and I don’t care about anything else. Mercedes E class speaks volumes about a person , from maybe this is the best i can do ...but it beats the shit out of that Camry ! To..I’m just getting started here !!! Oh I’m sorry, I didn’t see you had a car also...Camry person.
  11. Jan 22, 2018 at 8:16 PM
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    Not a lot of people are running bp51 setup. It would be hard for me to choose the bp51 over kings as they are proven, but I also don't know how you intend to use your truck.
    Coilovers or suspension in general can fail at anytime. So you may want to consider customer service, downtime for rebuild, maintainance in general etc.
    Tacomamike mike likes this.
  12. Jan 22, 2018 at 8:24 PM
    Tacomamike mike
    Michael
    I know a few people who are totally happy with the BP-51 setup . I bought the set because people like @Dissent86 who usd there trucks over and above what there capabilities are swore by them.
    Ahhh but I chickened out and went with Fox 2.5” DSC fronts and rears.
    Fox has always done right by me and I’ve used them extensively with a few rigs.
    OME BP-51 is owned by ARB, so I have to believe there customer services with the OME will reflect there there outstanding customer service they provide with the rest of there products.
    oscolivar1[QUOTED] likes this.
