Help deciding on lift!
Discussion in 'Suspension' started by Other Scott, Oct 21, 2012.
  1. Oct 21, 2012 at 4:10 AM
    Other Scott
    Other Scott [OP] Well-Known Member
    Mass.
    07 Access Cab V6 SR5
    Bilstien 5100's , 885's, 2.0 aal, and 265/75/16 on TRD wheels. Yellow fogs, fog light anytime mod. 2 meter ham radio, TRD exhaust. LED light bar.
    I put 5100's on my truck set at 1.75 , shortly after I bought a nice set of TRD wheels off eBay. I can see I opened up a can of worms here because now I want to lift the whole truck up another 1.25. So my question is which lift to buy, I would like to stick with toytec because I bought my bilstiens from then and was very happy with customer service when I called and the shipping was fast.
    My plan is to put 285's on after lift, so should I buy a kit w/out shocks or buy springs and AAL ?
  2. Oct 21, 2012 at 5:03 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Lets see some pics! Where in mass are you? Sounds like you know what you need, if it was my truck i would get new coils for the 5100s, AAL, new shocks and u-bolts for the rear. Good luck!
  3. Oct 21, 2012 at 5:13 AM
    donwsmith56
    donwsmith56 Member
    Don
    jackson, NJ
    2012 TRD OF access cab
    Any issues with the 1.75 lift in the front? Vibrations? I just bought a 12 trd OR and my head is spinning from all the post-options for lifting.
  4. Oct 21, 2012 at 6:05 AM
    Other Scott
    Mass.
    I put the bilstiens all around, so I don't think I'll need new rear shocks. Is there any difference in height between 884's ans 885's ? Downsmith56- no problems with vibrations untill a few weeks later when I was in some sand and started to spin the rear tires, so I put in four wheel drive and gently took a hard left to get off the beach where I was fishing. Drove up into a dirt parking lot and shut off four wheel drive, as soon as I got out onto the street I could tell something was wrong! Somehow I destroyed the passenger side needle bearing in the front diff. Really strange how a bearing would go south all of a sudden. Bad news is they where on backorder from Toyota , my mechanic in Tauton will have it this week. Should fix the vibration.
  5. Oct 21, 2012 at 6:19 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    I'd go with OME 885s and your 5100s set to .8.
    In the rear, look for either an AAL or replacement pack like OMe Dakars.
    This will allow you to clear 285s with minimal trimming.
  6. Oct 21, 2012 at 6:21 AM
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    x2
  7. Oct 21, 2012 at 6:58 AM
    Other Scott
    Mass.
    That's what I'll most likely do. What is your definition off minimal trimming?
    Also was planing on spider trax wheel spacers 1.25
  8. Oct 21, 2012 at 7:02 AM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    With 285s on stock wheels, you'll need to run the spacers.
    Minimal trimming typically involves removing front mudflaps and trimming the black plastic inner fender.
  9. Oct 21, 2012 at 9:07 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    884s are shorter, 10mm i think but im not positive. They both have the same spring rate. You might need to look into new UCAs i you go with 885s especially if you set your bilsteins at .8
  10. Oct 21, 2012 at 1:30 PM
    Other Scott
    Mass.
    Looks like I will get the 885's , now what would be better setting the Billy's at .85 or putting in a spacer to give me 3 inches of lift? Figured I would do the lift and see how the alignment come out before I buy UCA's
    To answer the question about vibrations, not at first till I toasted a diff bearing!
