Help Diag Clunk in front end
Discussion in '2nd Gen. Tacomas (2005-2015)' started by evile, Aug 10, 2012.
  1. Aug 10, 2012 at 6:00 PM
    evile
    evile [OP] Well-Known Member
    Orlando, Fl
    2006 DoubleCab TRD OffRoad PreRunner
    Bug shield vent visors Westin Chrome bull bar K&N Airfilter Pioneer CD/MP3/Ipod/DVD head unit KC Daylighters, LED map and dome lights, secondary airfilter removed. Black tube steps, 110v outlet in cab
    Checking to see if any one has run into this. I have got a clunk in the front end on hard turns and say a hard accel
    I have checked the ball joints upper and lower replaced the sway bar endlinks, the brake calipers are tight the pads are not moving cant seem to track down the noise. I am leaning towards the struts but figured I would see if any one else had a problem like this before I go replacing the stuts
  2. Aug 10, 2012 at 6:06 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    LCA bushings is my guess.
  3. Aug 10, 2012 at 6:11 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Make sure your driver side fender is bolted down tight and maybe lower the hood bump stops a pinch. :eek:
