Help diagnose death wobble!!
Discussion in 'Suspension' started by benbacher, Apr 13, 2013.
  1. Apr 14, 2013 at 6:21 AM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    There are no upper and lower ball joints on this axle. However worn trunnion bearing could attribute to DW.
  2. Apr 14, 2013 at 7:54 AM
    Cowboybob
    Cowboybob Well-Known Member
    Dooh....guess I should have watched the video before posting. I was just going by my previous experience and didn't realize he had a Birfield axle set-up vs ball joints. As redneck pointed out, check the bearings, but definitely check the track arm mounting as well as all the other bushings that locate the axle.
  3. Apr 15, 2013 at 9:29 AM
    mt sas
    mt sas Well-Known Member
    western montana
    fun
    S.A.S 21spline tcase highsteer
    I just fixed the same problem on my leaf sprung truck it wasn't a steering issue at all . I replaced all my spring to frame bushings after checking everything else a hundred times and it is gone. hope you guys figure it out it !
  4. Apr 16, 2013 at 1:23 PM
    benbacher
    benbacher [OP] Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Bump, any more advice?
  5. Apr 16, 2013 at 9:15 PM
    mt sas
    western montana
    fun
    hmm ? if all the steering parts are tight I would check out link connections any movement front to back in them can cause wobble . the slop in my spring bushings was causing my wobble . it seems like it should be steering component issues but would check out axel to frame connections . good luck !
  6. Apr 16, 2013 at 9:20 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    No Truck..well, maybe
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Is this "death wobble" the same as having a bad shimmy on a solid axle front end ? (excuse my ignorance with that term :anonymous::eek:)
  7. Apr 17, 2013 at 12:09 AM
    benbacher
    Anchorage, AK
    Yeah, check the video if you can doug, hahaha its a bit more than what I would describe as a 'shimmy'
  8. Apr 17, 2013 at 12:29 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Holy Balls !!! Yeah thats pretty bad def. something going on with the pass. side of steering/suspension Almost like a badly balanced (or no) tire/wheel but whats allowing it to do that is the problem maybe bent flange/spindle/ looks like a drag link type of steering (no pitman, is this correct ?) Drivers side looks like its behaving normally... wow...:notsure:
  9. Apr 17, 2013 at 12:37 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    That is if you've ruled out tie rod ends,etc:
  10. May 22, 2013 at 9:30 AM
    benbacher
    Anchorage, AK
    Tire was out of round all along. We put on some new 39 1/2" IROKS monday and it drives like a dream.
