Help Diagnose Drive Belt Noise Area 2001 Tacoma 3RZ-FE 2.7 L
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaNerd, Mar 26, 2011.
  1. Mar 26, 2011 at 3:13 PM
    TacomaNerd
    TacomaNerd [OP] Member
    Las Vegas, NV
    Tacoma 3RZ-FE 2.7 L
    Hi Guys,
    Was wondering if you could please help me diagnose the sound coming from my drive belt area. I have a 2001 4x4 Tacoma 3RZ-FE 2.7 L, manual transmission.
    I thought the noise might of been my drive belts, so I replaced all 3 belts. Power Steering, Alternator, and Compressor belt. All the pulley's seems fine when I checked it as I replaced the belts.
    It seems to only make the noise on cold start, and i notice the noise getting louder if I press on the gas or if i turn the steering wheel. Power steering fluid is full, might be old tho, but not sure if that matters. Once the engine is warm and I start to drive, the noise goes away.
    Any ideas?
    See Video
    http://www.youtube.com/watch?v=a7JztwsVR6w
  2. Mar 26, 2011 at 3:20 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Theres a screen in the reservoir of the power steering (IIRC) that might be blocked. It is a common occurance.
  3. Mar 26, 2011 at 3:26 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    I had the same issue, thought it was going to be a 30 dollar belt, turned out to be a 900 dollar rack and pinion.
  4. Mar 28, 2011 at 8:28 PM
    TacomaNerd
    Las Vegas, NV
    Tacoma 3RZ-FE 2.7 L
    I think that did the trick, I drained my old power steering fluid with a turkey baster, the bottom of the reservoir was gummy. Added more fluid, and haven't had that noise come back.
    Thanks!
  5. Mar 29, 2011 at 7:59 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  6. Mar 29, 2011 at 4:18 PM
    CdnSldr
    CdnSldr Well-Known Member
    Josh
    Northwestern Ontario (the only good part of ON)
    '96 Sex on Wheels ;)
    Deckplate mod, Bilstein 3" C/O's, NWO 2.5" rear leafs w/ overload, OME greasable Shackles, 33/12.5/15 Dura trac's, 15" Wheelers Steelies Type "B", Sat. Radio, Diff breather mod
    I guess in Las Vegas it doesnt really get cold, but up here in Canada my power steering is a bit louder on cold starts but quiets down after a few minutes of warming up.
    Glad you got it figured out!
  7. Mar 29, 2011 at 4:21 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You may want to check the screen in the bottom of your reservoir. They tend to get gunked up.
  8. Mar 29, 2011 at 4:36 PM
    CdnSldr
    Josh
    I recently sucked out all the fluid and then drained out the rest right from the rack. Then ran some cheap stuff thru with seafoam, then sucked/drained it out and refilled with good stuff. I HOPE the screen is fine. I had seafoam in there for about 4 days.
