Help Diagnose - Front End Noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by MTacoma, Sep 18, 2016.
  1. Sep 18, 2016 at 5:09 PM
    MTacoma
    MTacoma [OP] Active Member
    Flathead County
    2000 Tacoma
    2000 Tacoma 4x4 2.7L 3RZFE
    200,000 miles
    Front end noise / rattle/ knock. Been going on for at least 5,000 miles with no significant change. Can usually only hear it at idle and when driving it is not audible (but likely still happening).
    Harmonic balancer has slight wobble to it, but otherwise the motor is in great shape. I can feel a bit of vibration on the intake plenum that corresponds to the noise.
  2. Sep 20, 2016 at 7:02 AM
    MTacoma
    Flathead County
    2000 Tacoma
    Bump - any ideas
    The noise is that hollow rattle that seems to come and go
  3. Sep 20, 2016 at 7:18 AM
    98tacoma27
    Ben
    Not Beech Creek
    Could just be the harmonic balancer. I can't view the video right now. I'll have to check it later.
  4. Sep 20, 2016 at 7:35 AM
    MTacoma
    Flathead County
    2000 Tacoma
    Thanks - it definitely has a little wobble but nothing crazy.
    I originally thought it was a belt pulley with a bad bearing so i replaced one of the tensioner pulleys that was bad, but noise is still there.
  5. Sep 20, 2016 at 7:43 AM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Subbed :popcorn:. I have 2000 4 cyl prerunner that is a little louder than I would like after a head replacement.
  6. Sep 20, 2016 at 7:48 AM
    MTacoma
    Flathead County
    2000 Tacoma
    same noise tho? Did you replace timing chain/tensioner as well with head?
  7. Sep 20, 2016 at 7:56 AM
    DukesTaco
    AZ
    Yes I replace the tensioner when I did the head. I wouldn't say it's the same but the trucks are not side by side to listen too.
  8. Sep 20, 2016 at 7:59 AM
    DukesTaco
    AZ
    Heave you tried using a stethoscope (mechanics) or a long screw driver to your ear to isolate where it's coming from?
  9. Sep 20, 2016 at 8:34 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SLC
    2000 ext cab, 2.7L, auto, 4x4
    Just listened to your video, I know I've heard something like that before on a vehicle I worked on/repaired. But must've been a while ago. I can't put my finger on it. Damn this is driving me nuts. I know exactly the noise you're talking about though. It'll come to me. Give me a bit.
  10. Sep 20, 2016 at 9:36 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    pull the belt/belts see what it does? go away?,,, mine has 3 belts but it's a 95 2.7. if it has more than one, pull one at a time between starting.
  11. Sep 20, 2016 at 11:00 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    If I noticed my crankshaft belt pulley wobbling slightly, I'd fix it as soon as I could. I think that eventually the wobble will worsen to a point where it will eat away at the woodruff key that fixes the position of the pulley on the crankshaft and cause major crankshaft problems.
    Better to spend a few hours and a few bucks on a new pulley now than to replace the crankshaft later, don't you think?
  12. Sep 24, 2016 at 2:10 PM
    MTacoma
    Flathead County
    2000 Tacoma
    noise was coming from Alternator. what a relief.
    Water pump also had some play in its bearing so im putting a new one in too.
