Help diagnose my non-working cig lighter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 80sforlife, Jan 2, 2017.
  1. Jan 2, 2017 at 10:09 PM
    80sforlife
    80sforlife [OP] Well-Known Member
    2017 Toyota Tacoma DC TRDOR 4x4
    My cig lighter in the front dash isn't working anymore. I noticed it today when I tried to charge my phone. I tested another plug-in device and it still isn't working so it's definitely the cig lighter. Temporarily I'm using the backup cig lighter in the armrest console which is working fine. My first thought is maybe the fuse is burnt but I don't know where to check this. The owners manual doesn't have diagram of the fuse layouts. Appreciate the help!
  2. Jan 2, 2017 at 10:18 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    How far is a Toyota dealer ?
    George1441 likes this.
  3. Jan 2, 2017 at 10:27 PM
    the_dau
    the_dau Well-Known Member
    Vancouver BC
    2017 Inferno TRD OR DCSB
    take it to the dealer. you still have warranty
    George1441 and PROseur like this.
  4. Jan 2, 2017 at 10:41 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Ignition on, drive to dealer.
    But really, there should be a layout of fuses either printed on or a sticker applied to fuse panel cover.
    PROseur likes this.
  5. Jan 2, 2017 at 10:46 PM
    brentw59
    brentw59 Well-Known Member
    Brent
    Clovis CA
    2017 Tacoma 4x4 DCSB Manual Inferno
    Basic Shit. Floor Mats, Seat Covers
    Did you use a portable air compressor that plugs into the socket ever. I had one of those melt the wires on my old truck before and not blow a fuse. The cig lighter never worked after that. The fuse was fine it was the wires behind socket that were screwed from getting hot.
    bpx3075 and vinkon235 like this.
  6. Jan 3, 2017 at 5:50 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    @brentw59 Something was f'd up for that to happened. Avoiding melted wires (and maybe a fire) is sort of the whole point of having a fuse on the circuit... Either the wire had somehow ended up breaking enough internal strands to be unable to carry the rated current or someone (prior to you probably) had replaced a fuse with too high an amperage fuse.
    @80sforlife Just look on the plastic cover for the under-dash fuse panel. The two aux power outlets are labelled something like AUX1 and AUX2. Simple enough to tell if a fuse is blown.
  7. Jan 3, 2017 at 5:50 AM
    bpx3075
    bpx3075 Active Member
    2023 TRD OR Premium, 2017 TRD OR, 2012 TRD OR
    Mine died as well and I forgot to mention it when I took it in for the 5k service because like you it was a minor inconvenience and Ive been using the one in the armrest console.
  8. Jan 3, 2017 at 5:55 AM
    bpx3075
    Interesting... I used my portable air compressor a few times in the front cig lighter after I first bought the truck.
  9. Jan 3, 2017 at 8:56 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    I wouldn't worry about using your air compressor. The wires are sized to handle the amperage. And if you go over the amperage the fuse will blow. There was another issue which caused his wife's to melt. Like a wrong fuse or maybe a loose connection which caused arcing.
  10. Jan 3, 2017 at 3:59 PM
    brentw59
    Brent
    Clovis CA
    I was talking to a buddy about it at work today same thing happened to him while camping. Used his portable to air up his tire all the way so about 15min with a portable when he went to pull the plug out of the cig socket the whole socket pulled out of the dash he said it was super hot. He had a 2002 extra cab 2wd mine was a 2001 single cab 2wd. I agree the fuse should blow not sure why that would happen but it did.
  11. Jan 3, 2017 at 4:05 PM
    brentw59
    Brent
    Clovis CA
    I searched around and other people have had the same issue while using air compressors. A few others with toyota trucks and a few with camrys.
  12. Jan 3, 2017 at 4:09 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
