Help diagnose noise...rear diff?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by snau, Jun 6, 2021.
  1. Jun 6, 2021 at 1:33 PM
    snau
    snau [OP] Member
    2020 Sport
    I just came back from a 5k trip from MD to CO and back and developed a noise under acceleration about half way through the trip.
    At first I thought it was something loose with the exhaust. I had swapped out the stock, then wife vetoed the new exhaust (loud as f*ck when towing, I agree) so I thought maybe I needed to tighten down exhaust bolts or I missed a hangar....that's not it.
    The sounds starts to show up at about 30-35 mph and gets louder as I speed up -- but ONLY when I'm accelerating. If I take my foot off the gas and just coast it sounds normal.
    I've got about 10k miles on a Nitro 5.29 set of gears and starting to think that something might be wrong...was under the truck looking for something loose and the rear diff was still warm to the touch about 30 mins after parking. It's a 2020 sport with only 25k miles but has seen a bunch of towing...
    Thanks for any ideas!
  2. Jun 6, 2021 at 1:58 PM
    513Mugsy
    513Mugsy Well-Known Member
    Cincy
    2020 VOODOO AC OR MT sold now
    Just a starting point. Open the fill on the rear diff while sitting level. See if any oil runs out, or if you can feel any with the pinky finger test. If not, start adding. Might be time to just change it anyways if you have towed a lot.
  3. Jun 6, 2021 at 4:51 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Yeah change the rear diff fluid, and see if you notice any shavings or chunks.
  4. Jun 6, 2021 at 4:56 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    What's the noise sound like? Whine? Hiss? Clank? Rattle? Light throttle or heavy?
  5. Jun 10, 2021 at 2:36 PM
    snau
    snau [OP] Member
    2020 Sport
    Ok update -- changed out all the fluid in the diffs and the transfer case. Oil was dirty but nothing that looked too bad. Noise is the same...it sounds like light tinny rattle. Happens when I'm light on the gas, even just tapping it.
  6. Jun 10, 2021 at 2:53 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Exhaust heat shield somewhere?
  7. Jun 10, 2021 at 3:05 PM
    snau
    snau [OP] Member
    2020 Sport
    I've been under there looking for something loose and don't see anything...at this point I might just start taking things off!
