help diagnosing a problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by fireturk41, Aug 13, 2009.
  1. Aug 13, 2009 at 6:04 AM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    ok i have a 02 toyota taco with a V6 3.4L engine. every once in awhile (maybe 5-10% of the time cranking) i crank the engine it turns over but the engine stays under 1k rpm and dies, then i have to crank it and lay on the gas and it fires right up, it did this when i changed my battery and the ECU reset itself, i expected it to "relearn itself" within 30-50 miles, but this problem is startin to worry me a lil
  2. Aug 13, 2009 at 6:08 AM
    98tacoma27
    Ben
    Not Beech Creek
    Clean your throttle body and the Idle Control valve.
  3. Aug 13, 2009 at 7:01 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    Thats nuts because mine does the samething idles real rough and spudders but if you hit the gas it will run fine. I cleaned my throttle body and MAF and it seems to be working alot better now.
    Glad to see I'm not the only one having this problem sometimes lol
  4. Aug 13, 2009 at 7:04 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Had to get my idle control valve changed. On my 2002.
  5. Aug 13, 2009 at 7:40 AM
    98tacoma27
    Ben
    Not Beech Creek
    Cleaning the MAF is a great idea too.
  6. Aug 13, 2009 at 7:49 AM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    Sorry,What's MAF ? :(
  7. Aug 13, 2009 at 8:58 AM
    stucksucksnayota
    Barry
    Mass Air Flow Sensor I think lol. To get to it just pull that air box out that your air filter sits in and then take part of the tube off. You should see some wires plug into that air intake tube. It is a thin piece of wire (becareful and dont touch it) just spray it off with some MAF cleaner.
  8. Aug 13, 2009 at 12:56 PM
    98tacoma27
    Ben
    Not Beech Creek
    :thumbsup:
  9. Aug 13, 2009 at 12:59 PM
    97Blk_one
    Memfrica
    not so low
    Thanks. I'm looking for it now..sorry :D
  10. Aug 13, 2009 at 8:57 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    ok thanks guys, ill get on it
    also have another problem, gahh now at every gas station i go to withthe exception of one i cant pump gas correctly, it triggers the mechanism on the pump that tell it the tank is full, while my tank is empty
  11. Aug 13, 2009 at 8:58 PM
    98tacoma27
    Ben
    Not Beech Creek
    Don't put the nozzle all the way in.
    :D
