Help diagnosing front diff/wheel bearing noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Badwin45, Sep 10, 2012.
  1. Sep 10, 2012 at 2:06 PM
    Badwin45
    Badwin45 [OP] Well-Known Member
    OKC
    '10 DC 4x4 & '00 Pre-Runner
    Aries 4" Oval step tubes, Brute Force Fab rear bumper, Weathertech digifit floor liners.
    Guys,
    I could use a little help diagnosing a noise that appears to be coming from the right front wheel on my 2010. It's cyclic and sounds like I'm running a MT and gets slightly louder when braking or turning left. I've jacked up that wheel and tried to move it @ top/bottom but can't feel any play and I don't feel any roughness when I rotate the hub by hand either with or without the wheel installed. Any thoughts?
    This is an unmodified truck with 62K on the odo.
    ETA: Engaging 4hi makes no difference.
    TIA
  2. Sep 10, 2012 at 2:29 PM
    BamaToy1997
    Bill
    Navarre, FL
    Lift the truck and check both sides. Although sometimes the worn bearing won't have enough play to show even though it is making noise. If you are positive it is coming from the right front, then your description of the noise is exactly like that of a bad bearing.
  3. Sep 10, 2012 at 2:36 PM
    Badwin45
    OKC
    Thanks BamaToy. I'm "pretty sure" that's where it's coming from. That's where I think I hear it (I'm deaf in one ear and can't hear outta the other) and that's where bosslady and baby troll tell me it's coming from so that's likely it.
    Now, due to your sig, the rest of my day has been shot.
  4. Sep 11, 2012 at 5:28 AM
    BamaToy1997
    Bill
    Navarre, FL
    Thank you. I love my sig. Sorry about your productivity for the day. lol
  5. Nov 13, 2012 at 9:55 AM
    Badwin45
    OKC
    Now with more confusion added!
    I have the hub assembly off and I can now spin it freely by hand. Smooth as a baby's ass. Now what? Any ideas?
  6. Nov 13, 2012 at 10:22 AM
    TscotR214
    TscotR214 Well-Known Member
    Scot
    Santa Cruz Ca
    '15 DCSB Overland Rig
    Bearing! Just had same issue with my front left. Noise changes when turning (puts more or less weight on wheel, changes stress load on bearing). Jacked truck up, couldn't feel anything, no play, same as you. Took to dealer, replaced both front bearings just for the heck of it. Problem solved. Yeah, expensive service, but something you can't really diagnose yourself as the truck has to be under load and at speed to stress the bearing.
  7. Nov 13, 2012 at 10:54 PM
    Badwin45
    OKC
    Fuuuuuuuuuu....
    Replaced the bearing. No change.
  8. Nov 14, 2012 at 5:45 AM
    BamaToy1997
    Bill
    Navarre, FL
    Remember I had mentioned that sometimes the noise may APPEAR to be coming from one side, when it is actually from the other. Did you lift the truck up and check BOTH sides before replacing the bearing?
  9. Nov 14, 2012 at 6:34 AM
    Badwin45
    OKC
    Yep. Neither side had any visible play in it or any roughness when turned by hand. Rotating the tires makes no difference nor does putting it in 4wd.
  10. Nov 14, 2012 at 11:16 AM
    BamaToy1997
    Bill
    Navarre, FL
    Hmmm. Sounding more like a CV axle issue, but remember we are only able to guess based on input. Perhaps take it in to a good local shop and have them check it out? Sadly enough I HAVE seen bearings that spun perfect by hand, yet failed under load....
