Help diagnosing my Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tensecondchevelle, Sep 12, 2014.
  1. Sep 12, 2014 at 11:41 PM
    tensecondchevelle
    tensecondchevelle [OP] Well-Known Member
    Eric
    Mesa Arizona
    2006 Tacoma Double Cab
    Earlier tonight I was driving around and heard my truck was making a winning noise. At first it seemed like it was only when I had my air conditioner on, so I turned it off then a few minutes later I heard it start again. I decided it was likely a belt and figured I would get it checked out tomorrow.
    As I was dropping off my fiancee I had my truck in park and the radio completely lost power and shut off. Thinking something weird just happened with the radio I turned off the truck and it would no longer crank, just click. Pulled out the jumper cables and it fired right up.
    As long as I am giving the truck gas the radio still stays on, if I am coasting to a traffic light or braking the radio still lose power and turn off (one time the battery light came on while the truck was just idling). Currently the truck is sitting in my driveway dead again.
    Any thoughts? My initial thought is it's a belt issue seeing that I only lose power when I am not accelerating. That being said I don't know as much about fixing vehicles as I would like , I only know how to break them.
  2. Sep 13, 2014 at 12:06 AM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Autoparts stores all do it as far as I know. Is it just the radio shutting off or are your headlights dimming/other electrical components as well? I can't say I've ever heard of an alternator slowly dying, usually they just go and you limp on battery power til it's drained but it could happen I suppose. If your A/C is working I doubt you have an electrical issue in that system.
  3. Sep 13, 2014 at 12:10 AM
    tensecondchevelle
    Eric
    Mesa Arizona
    When my truck was turned off the headlights were flickering and getting dim. I can't say that was the case when my truck was running and I was stopped as I was always at a traffic light and there were too many street lights to notice any flickering or dimming.
  4. Sep 13, 2014 at 12:15 AM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    Your alternator just took a shit..
  5. Sep 13, 2014 at 12:27 AM
    anotherreject
    anotherreject Well-Known Member
    I had similar symptoms when my battery completely died
  6. Sep 13, 2014 at 12:38 AM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I've seen a corroded Terminal on the negative side of the battery do that also.
  7. Sep 13, 2014 at 2:21 AM
    BigBiscuit
    BigBiscuit Well-Known Member
    Mass.
    2010 TRD Sport DCSB MGM
    It's your alternator.
  8. Sep 13, 2014 at 8:20 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    While it could be a failing alternator, it sounds far more likely to be a battery or connection problem. Unless you want to chase your tail and replace parts until the problem goes away, start with a load test of the battery and check all connections. Then test the alternator output, or take it somewhere that can. A battery with a shorted cell could certainly cause your symptoms.
  9. Sep 13, 2014 at 8:47 AM
    diesel305
    diesel305 Active Member
    miami, fl
    2011 tacoma prerunner DCSB trd sport
    This
  10. Sep 13, 2014 at 9:09 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    My alternator was slowly dying, from my pulling too much from it with my stereo. The symtoms you describe sound like a seized bearing in the alternator, so it's not powering the truck anymore. Do you have a DMM, or something, that will tell you voltages with and without the truck running? Would help in diagnosis.
  11. Sep 13, 2014 at 9:15 AM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    From what you described, my vote is for the alternator.
  12. Sep 13, 2014 at 9:47 AM
    J.Z.Alba
    J.Z.Alba Well-Known Member
    Jer
    San Diego
    2015 Tacoma DCLB Pre-runner TRD
    Nerf steps, Fold-A-Cover
    Sounds to me it's the alternator..
  13. Sep 13, 2014 at 12:20 PM
    tensecondchevelle
    Eric
    Mesa Arizona
    So we took it to the local auto parts store, they hooked it up and concluded it was the alternator. My belt is getting pretty warn so we may replace that while we are at it
  14. Sep 14, 2014 at 1:26 PM
    tensecondchevelle
    Eric
    Mesa Arizona
    I'll check them out, thanks. Alternator is fixed and truck up and running again. Alternator cost was $150 and labor was $60 for the alternator and belt to be installed.
  15. Sep 14, 2014 at 1:32 PM
    tensecondchevelle
    Eric
    Mesa Arizona
    It was a family friend that took care of me. What would normal labor be for a job similar to this?
