HELP, Differential Oil Advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brandonlamb25, Nov 29, 2010.
  1. Nov 29, 2010 at 6:40 PM
    brandonlamb25
    brandonlamb25 [OP] Well-Known Member
    Georgia
    08 Crewcab Prerunner V6
    K&N Intake, Wet Okole Seat Covers, Ipod to Factory radio hookup kit, Black Low Pro Toolbox, Toytec Coilovers and 285/75r16 BFG MT's
  2. Nov 29, 2010 at 6:43 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    do you have a LSD?
  3. Nov 29, 2010 at 6:45 PM
    brandonlamb25
    Georgia
    no
  4. Nov 29, 2010 at 6:46 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
  5. Nov 29, 2010 at 6:47 PM
    98tacoma27
    Ben
    Not Beech Creek
    Mobile 1 is great. So is Amsoil severe gear. Rotella is good for dyno oil.
  6. Nov 29, 2010 at 6:49 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    that redline is also excellent, but the mobil 1 can be found at any auto parts store.
  7. Nov 29, 2010 at 7:04 PM
    brandonlamb25
    Georgia
    ok, so sounds like mobil 1 is the fave. and local is good too. will toyota give me any shit for not using their oil??
  8. Nov 29, 2010 at 9:26 PM
    Taco11
    Taco11 Well-Known Member
    Seattle WA
    No they can't. If they do.. they are breaking the law. You can use ANY oil that meets the specs stated by Toyota.
  9. Nov 29, 2010 at 9:36 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Not to hijack the thread but every bottle of Mobile One gear oil I've seen has LS on the outside. Do they even make a 75-90 for non limited slip applications?
  10. Nov 30, 2010 at 7:22 AM
    brandonlamb25
    Georgia
    good question. do they?? i have an open diff.
  11. Nov 30, 2010 at 8:11 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    it doesn't matter if it has the additive, plus lots of people have had problems running the mobil 1 in the LSD, thats why I asked if he had one.
    Im running mobil 1 75-90 in my sr5 open diff with no problems.
  12. Nov 30, 2010 at 8:22 AM
    MAtrdguy
    MAtrdguy Well-Known Member
    Pete
    Western Ma ( on the lake) / Danvers N Shore
    06 Taco DC LB
    None YET
    so have I...ran it in my Tundra for years and in my Taco now...no problems!!
  13. Nov 18, 2013 at 12:02 PM
    Juddly450
    Juddly450 Member
    Hermosa
    PreRunner
    I have an 08' prerunner with LSD (red sticker on) and used Mobil 1 WITH the LSD additive...I then noticed a slight grind, vibration each time I'd turn left or right at about a 45deg angle. I searched for advice on this forum, spoke to several mechanics, and was assured that in no way is that rub, vibration correlated with the rear diff oil.
    UNTIL...finally, I came across a single post on this forum that had to do with driveshaft vibration that said all he did was change the rear diff oil and problem solved...So, I decided to change the oil again, this time I used Valvoline full synthetic (that has the LSD additiv), AND I also purchased the separate tube of LSD additive. I put in 1 bottle of oil, then the additive, then filled the rest up until started to slightly drip out of the fill hole.
    Whammy...problem solved, absolutely no rub, vibration, or anything else that made me cringe every time I backed out of the driveway.
    Hope this helps someone else out there some time, money, and their ears from such a gawd awful sound!
  14. Nov 18, 2013 at 12:38 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I was buying stuff at the dealership for my 30K maintenance and asked for gear oil -- they don't have it in the Toyota containers, they buy it in bulk and couldn't sell it to me. So I just got the Valvoline synthetic blend at AutoZone, which is probably as good or better than what they would use.
    Some diff manufacturers actually recommend using dino oil. Even on a set of diffs that sees reasonably tough use, a 30K change interval with name-brand dino oil should be fine.
    Pretty much all gear oil they sell at your local parts store can be used in open and LSD, you just need to use the additive in an LSD.
