HELP! Dimensions for blocks
Discussion in 'Suspension' started by durf4694, May 5, 2011.
  1. May 5, 2011 at 6:23 PM
    durf4694
    durf4694 [OP] giggity giggity
    ny
    06 tacoma sport
    K&N cold air kit, Kenwood double din with dvd player, navigation, rear cam. hook up with One JL 12" sub powered by a 800 watt pioneer amp, Sirius/XM satellite radio, TRD Neoprene Seat covers, Tinted windows all around, Trifecta Tonneau Cover, Billies at 1.75 and a 1.5 block in the back
    Im looking to make some 1.5 lift blocks and i was wondering if anyone could tell me the size of the pin on top of the block (diameter and height) and the hole on the bottom of the block. i'd really appreciate it thank you!!
  2. May 5, 2011 at 6:26 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    You'd be happier and time and aggravation ahead if you
    went aal... you can get em for like 70 bucks I believe
  3. May 5, 2011 at 6:35 PM
    durf4694
    ny
    06 tacoma sport
    yea i did my research and im not a wheeler so the block should suit my application just fine. thanks for the advice though!!
  4. May 5, 2011 at 6:39 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Alrighty then sounds good! sorry cant help ya withe dimensions though... :eek:
  5. May 10, 2011 at 6:43 PM
    durf4694
    ny
    06 tacoma sport
  6. May 10, 2011 at 7:42 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    hell I have a set of 3.5" blocks in the garage...but the garage is 56 miles away! Sorry....
    P.S. if blocks is what you want then don't let anyone tell you otherwise. It's your truck after all. I had those 3.5" for 3 years with no issues. Even took it off roading in Arkansas back when I use to take it off roading and they worked great even with holding 4 wheelers in the bed!
    hope it works out!
  7. May 10, 2011 at 8:05 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I'd be more worried about axle wrap on road, than anything offroad.
  8. May 10, 2011 at 8:36 PM
    brelandt
    Terry
    Dublin, CA
    On the thin leaf taco springs it was there, but it wasn't terrible. Didn't have any issues. Might have just been me???? I don't know? But early Rangers came with them stock and there are even heavy trucks, like buses and dump trucks running blocks on the front leaf and in fact they have been used for years. Just give it a try and if they do not perform the way you like then move on to something else.
  9. May 12, 2011 at 6:08 PM
    durf4694
    ny
    06 tacoma sport
    thank you !!!!!!!!!!!!! took me fricken forever to get them . time to make some chips!
  10. May 15, 2011 at 10:00 AM
    durf4694
    ny
    06 tacoma sport
    why did you have to measure your centering pin when you put the shims in ? im guessing b/c they sat under the whole entire block
