HELP! Don't know how to remove tranny fluid filter!
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomatt602, Aug 2, 2015.
  1. Aug 2, 2015 at 6:31 PM
    tacomatt602
    tacomatt602 [OP] Well-Known Member
    Phoenix, AZ
    1997 5lug Regular Cab 2.4l
    Doetsch spindles, V6 coils, Fabtech AAL, 4Crawler 2" body lift, Daystar coil spacers, Bilstein 5100s (rear), 15x7 U.S. Wheel Stealth Stars, 225/70r15 Firestone Destination LE2s, '00-04 side mirrors, Prerunner/4x4 grille, Kobalt low-profile toolbox, fucked steering rack D:
    FOR AN A43D TRANSMISSION (4-speed auto)
    So I decided to change my transmission fluid and filter today. So far, everything's gone fairly smooth. But now I've hit a wall. I drained the fluid, removed the pan, cleaned it, cleaned the gasket surfaces, and now I'm trying to remove the filter but it won't jimmy out without removing anything else.
    Anybody who has experience with this, any info would be appreciated.
    Sun goes down in an hour! D:
  2. Aug 2, 2015 at 6:33 PM
    tacomatt602
    Phoenix, AZ
  3. Aug 2, 2015 at 6:36 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    subbed for outcome
  4. Aug 2, 2015 at 8:02 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    well in the video it looks nothing like yours, but this is the way the filter is replaced
    https://www.youtube.com/watch?v=FglBsUEOSEk
    off hand I would say it should be able to slide out from under that tube crossing over it but you better check the FSM to be sure
  5. Aug 2, 2015 at 8:07 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    95 extended cab sr5
    cxr turbo, fic6, methanol injection, king coilovers, jba uca, skyjacker leafs, rear 12" 5125s, no-slip rear locker, 35" grabber x3, magnaflow muffler, retrofit headlights, trans cooler, bed lined exterior, etc...
    thats the v6 auto.
  6. Aug 2, 2015 at 8:08 PM
    keakar
    karl
    louisiana
    ahh, they don't always say the engine types but it figures, most everything they have on youtube is for v6 engines
  7. Aug 2, 2015 at 11:32 PM
    tacomatt602
    Phoenix, AZ
    Ok guys, my neighbor figured it out for me. Idk if this is the right way to do it but it worked lol
    He basically stuck a screwdriver between the filter & that tube, then pried the tube down far enough so that the filter could slide out toward us (with respect to the pictures). He seemed pretty confident about what he was doing, since he's got about 10 years of experience with cars, but so far nothing bad has happened.
    Fingers crossed!
  8. Aug 2, 2015 at 11:44 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    Haynes manuals are your friend!
  9. Aug 3, 2015 at 12:04 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Shit, im soon to do this on my 2.7L. Odd, its all A340 transmissions in these. Surprised it would be different on the 2.4L.
