Help - Drained Transmission Oil and added additional 5.5qts to regular oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaOwner21, Nov 18, 2022.
  1. Nov 18, 2022 at 3:03 PM
    TacomaOwner21
    TacomaOwner21 [OP] New Member
    Victor
    2015 White Tacoma PreRunner
    I know I am going to get a lot of heat for this but I changed my oil for the first time about two weeks ago and just realized today that I made a huge mistake. I drained my transmission oil instead of the engine oil and added 5.5qts of new engine oil in addition to the old stuff that's in there. I noticed some shifting issues today and realized I messed up bad. What can I expect and how bad is this issue? Can I just drain the engine oil, add the correct amount of new engine oil, and add new transmission oil? If not how much will it cost to fix it? (Edit: I've already driven about 450 miles)
  2. Nov 18, 2022 at 3:14 PM
    Kiddog78
    Kiddog78 Member
    2012 TRD Crew Cab, long bef
    Lear topper, Rhino springs
    I did too, 7 years ago when I did my first oil change after the dealer free changes ended. Taco tranny drain is same place as my f150 oil drain was. 80,000 miles later motor & tranny are both still good. I did only drive 30 miles like that though.
    I drained the oil down but paid dealer to service the tranny. I wish you luck
  3. Nov 18, 2022 at 3:23 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    I'll post it before someone else does... This Needs To Be a STICKY. Happens too often.
    I can't comment on your tranny but... how the hell do you not drain your oil, add 5.5 qt. and not find it over filled?
    Not trying to be a d*%$ but that's just standard operating procedure.
    Good luck.
    amyracecar and wilcam47 like this.
  4. Nov 18, 2022 at 3:25 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    Yup, the only thing you can do is fix what’s wrong and move on. If something got damaged you’ll eventually find out. You’re not the only one to do this. Look for a classic thread from krazie sj if you need a good laugh.
    https://www.tacomaworld.com/threads/halp.33318/
    jackn7, Hyperbarics, Jaypown and 3 others like this.
  5. Nov 18, 2022 at 3:25 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Happy Friday y’all
    jackn7, Superdave1.0, JimIowa and 3 others like this.
  6. Nov 18, 2022 at 3:25 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Transmission fluid is red for older Yota's; does that apply to 2nd Gen and above?
  7. Nov 18, 2022 at 3:27 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    That all that needs to be said. :thumbsup:
    Fix mistake, learn from it, move on.
    Jimmyh, winkel and whatstcp[QUOTED] like this.
  8. Nov 18, 2022 at 3:30 PM
    TnShooter
    Deogee
    STOCK
    If you haven’t noticed a problem in 450 miles, you probably don’t have a problem.
    It happens, we all make mistakes.
    Learn from it and drive on:thumbsup:
  9. Nov 18, 2022 at 3:34 PM
    road2cycle
    Sonoma County, CA
    It’s brown if it hasn’t been changed in 100k miles.
    wi_taco likes this.
  10. Nov 18, 2022 at 3:50 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Do a search on transmission fluid level. Your truck may not have a transmission dipstick.
  11. Nov 18, 2022 at 4:04 PM
    Bishop84
    Bishop84 Well-Known Member
    Mistakes happen, owning is big.
    That said, the trans isn't simple to fill and if you drained it, it would have serious issues driving and going into gear.
    Also typically when the engine is double filled it usually causes misfires.
    What gave away the error?
    I would just take it to a shop and eat the costs.
  12. Nov 18, 2022 at 4:24 PM
    TacomaOwner21
    Victor
    I hadn't had any issues for about two weeks (~450miles) but today I went on the highway and got up to higher speeds and it felt like my truck was stuck in a gear, wasn't shifting properly, and the RPMs were getting higher than usual. That's when I realized I probably did something wrong on the oil change. Went back and looked through some videos and research to realize that I drained the wrong oil pan.
  13. Nov 18, 2022 at 4:40 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I've read so many of these threads that the first time I crawled under the truck I triple checked which was which, pointing at oil pan and trans pan like it was a game of eeny-meeny.
    I can see how the mistake is made, the oil plug is concealed behind a cover on some trims. Granted it's easy to to distinguish when you look to see what each pan is hanging onto. But I get it. I can see how people would pull the first plug they see that's within the general vicinity, and that's usually not the oil plug.
  14. Nov 18, 2022 at 7:08 PM
    TnShooter
    Deogee
    STOCK
    2 weeks and 450 miles with 11 quarts of oil in the engine and low trans fluid.
    I would think the you’d have noticed sooner. Impressive none the less.
    And no offense to you man.
    Again, it happens.
    As long as all the fluids are at the correct level, and you have no problems, there isn’t much you can do.
    Again, I stress the fluid levels should be at proper level, the A750 can be hard to fill correctly if you haven’t done it before.
    dk_crew, road2cycle and wilcam47 like this.
  15. Nov 18, 2022 at 7:23 PM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    LOL
    And if you want the follow up to the Krazy oil change, be sure to read up on how he does a suspension install, link in my sig :rofl:
  16. Nov 18, 2022 at 7:25 PM
    TnShooter
    Deogee
    STOCK
    I take it you weren’t around for the “homemade” lift kit thread, huh?
  17. Nov 18, 2022 at 7:26 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    HALP!!!
    OP, 450 miles I would think there is serious damage done. But hey, just drain and refill both and keep driving if no issues show up. Just keep in mind years from now if you start having issues, this is what cause it.
    cryptolime and wilcam47 like this.
  18. Nov 18, 2022 at 7:29 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Gosh all almighty …
  19. Nov 18, 2022 at 7:30 PM
    TurboGT
    Gabe
    Portland
    Not sure what you mean by that, but by all means post a link to it...
    The day I signed up for TW was the day I almost got myself fired for reading through 15 pages of Krazy's lift thread and then way too many pages of the oil change thread. If it happened before that, I haven't yet seen it.
  20. Nov 18, 2022 at 7:30 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Link?
