Help! Driving in 4 vs D
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sblspawn, Nov 15, 2018.
  1. Nov 15, 2018 at 3:49 PM
    sblspawn
    sblspawn [OP] Well-Known Member
    Guys, my Tacoma shift very rough between 30mph and 40mph when I drive the truck in D. I can feel the tranny jerking upshifting and downshifting sometimes if I stay around those miles and it's annoying. But if I change the shift to 4, the tranny shifts softer and I don't feel any hard shifting like when is on D. I don't really know what is the difference between D and 4 and if I can drive the truck in 4 all the time without damaging the tranny. Some help will be appreciate it!
    GrandTheftAngel likes this.
  2. Nov 15, 2018 at 3:51 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Sounds like your transmission is already damaged
    El Duderino likes this.
  3. Nov 15, 2018 at 3:54 PM
    tcjacado
    tcjacado Well-Known Member
    You can drive the truck all day in 4.
    Driving In S mode only allows the transmission to shift upto that gear. So driving in s4 means it will redline and still not go into 5th gear. The 5th and 6th gear are overdrive meant for speeds above 50 mph.
    So 5th would be 50 to 70 and 6th 70 to beyond.
    Driving in s mode the truck doesn't learn as it does in D mode
  4. Nov 15, 2018 at 3:54 PM
    sblspawn
    Maybe I exaggerate a little! It's not really happening all the time! Sometimes the truck change smooth.
  5. Nov 15, 2018 at 3:57 PM
    sblspawn
    Good info! Thanks man! So when I drive in 4 should I stay below 50mph or it doesn't matter what speed I reach?
    TRDSport10 likes this.
  6. Nov 15, 2018 at 3:59 PM
    tcjacado
    Whatever 4th gear will top out at. Yes below 45 stay in 4th. Get on the highway/freeway put it in D or knock the gear selector forward for appropriate speed.
  7. Nov 15, 2018 at 4:00 PM
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    Are you covered under warranty, how many miles?
  8. Nov 15, 2018 at 4:02 PM
    sblspawn
    No warranty! 46000
  9. Nov 15, 2018 at 4:03 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    4 for the city D for highway speeds and above is my rule of thumb.
    I would actually suggest you get your transmission fluid level checked by someone who has experience with these new generation Toyota transmissions. It somewhat sounds like you may be low if you are gear hunting as much as you say and if the transmission is as jerky as you say it is. Some gear hunting is normal for the shift logic on the 2nd gens, especially on inclines during highway runs but if you are gear hunting on flat ground at random, yeah... fluid level is highly suspect if so.
    Skyway, mbrogz3000 and sblspawn[OP] like this.
  10. Nov 15, 2018 at 4:07 PM
    sblspawn
    The problem is that you know what they say when the truck has being modified.
  11. Nov 15, 2018 at 4:08 PM
    tcjacado
    Are you a 2nd or 3rd gen
  12. Nov 15, 2018 at 4:09 PM
    sblspawn
    It could be! Something to keep in mind! Thanks bro!
    12TRDTacoma[QUOTED] likes this.
  13. Nov 15, 2018 at 4:10 PM
    sblspawn
    2nd 2015 Prerunner
  14. Nov 15, 2018 at 4:13 PM
    tcjacado
    The tsb may not apply, sorry my mistake. Driving and thought you were a 3rd gen with shifting issue. :oops:
  15. Nov 15, 2018 at 4:13 PM
    sblspawn
    I imagine seen the idiot at the dealer saying; "Your transmission is acting like this because the truck is lifted" Jerks!
    Bebop likes this.
  16. Nov 15, 2018 at 4:14 PM
    sblspawn
    I could try the dealer, but without any hope!:rolleyes:
  17. Nov 15, 2018 at 4:15 PM
    tcjacado
    They love to say that dont they.... go to another dealer if you can. Should be under the drive train warranty which is 60k I believe.
    sblspawn[QUOTED][OP] likes this.
  18. Nov 15, 2018 at 4:19 PM
    sblspawn
    The drive train warranty specify that the Truck have to be without any modification to be covered.
  19. Nov 15, 2018 at 4:24 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    This is what they told me when I had my torque converter shutter. Idiots...
  20. Nov 15, 2018 at 4:26 PM
    tcjacado
