Help, engine only idles if I keep my foot on gas pedal, dies if I let go.
Discussion in '1st Gen. Tacomas (1995-2004)' started by chilicoke, Jul 29, 2012.
  1. Jul 29, 2012 at 7:07 PM
    chilicoke
    chilicoke [OP] Active Member
    Irvine, CA
    01 PreRunner DC
    Hello TacomaWorld, new member here, just registered but had been lurking for information which ultimately helped me in successfuly buying a stock radiant red 01 V6 AT PreRunner DC TRD a little over a month ago.
    Since then, I've enjoy driving it so much that it quickly became my daily driver. Did the deck plate mod this past weekend and it drove great, intake roar was exhilarating.
    Last night, after a few WOT the engine stalled. No CEL, engine cranks, takes a little bit longer to start but dies right away unless I keep my foot lightly on the throttle.
    I have checked vacuum lines and found no cracks. EFI fuse in good condition, and have swapped EFI relay with TAIL relay with no improvements. My best guess is maybe a bad fuel pump, but would appreciate any inputs.
    Few questions:
    - does the Tacoma prime the fuel pump when key is in "ON" position? I do not hear anything from the back side of the cabin.
    - with a OBD2 reader in real-time mode, fuel pump #1 indicates "CL' (closed loop?), while #2 indicated N/A, is this normal?
    Thanks! :)
  2. Jul 29, 2012 at 7:10 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    is your maf sensor in backwards???
    sounds stupid i know, but ive done it .....
  3. Jul 29, 2012 at 7:22 PM
    chilicoke
    Irvine, CA
    01 PreRunner DC
    Thanks for the reply buldas,
    I just went out and checked, noticed that there's a plastic "shield" that only allows the maf sensor to be installed in one direction, and I remember the harness clip faces upwards before taking it off.
  4. Jul 29, 2012 at 7:24 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Sounds like the throttle position sensor or crankshaft position sensor to me and depending on the mileage I'd change out the exhaust O2 sensor (s). When its running is there little or good flow out the exhaust tip (with your hand over the tip) could indicate a plugged cat.
    Check the wiring around the EGR valve isn't pinched or burned.
    Make sure the throttle body itself is bolted tight on the manifold.
    Sorry I can't offer any other help.
  5. Jul 29, 2012 at 7:27 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    pull your throttle body and clean the idle air control valve. I have 2 3.4L V6 in the yard that had idle problems and cleaned both iac valves and all is well.
  6. Jul 30, 2012 at 10:16 AM
    chilicoke
    Irvine, CA
    01 PreRunner DC
    Thank you guys a million! Pulled the throttle body and idle air control valve last night and found nasty amount of carbon buildup. After a thorough cleaning the truck idles and runs smoother than ever.
    I guess it might be a good idea to run a bottle of sea foam to clean the rest of the engine.
  7. Jul 30, 2012 at 10:21 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    :yay: Glad it is running good.
  8. Jul 31, 2012 at 5:08 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    What method did you use to get your IAC that clean? Very nice
  9. Jul 31, 2012 at 5:31 PM
    BrianLV
    BrianLV Well-Known Member
    Las Vegas
    04 Prerunner SR5
    How many miles?
  10. Jul 31, 2012 at 6:03 PM
    chilicoke
    Irvine, CA
    01 PreRunner DC
    Just a bottle of CRC Throttle Body cleaner and a lot of q-tips. 150k miles on the taco. :)
  11. Jul 31, 2012 at 7:03 PM
    2000GTacoma
    Snow Hill NC
    I figured thats what it was. Most of the time idle problems are caused by that. Good to know its running well now.
  12. Jul 31, 2012 at 7:45 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Now how's he supposed to do that if he can't take his foot off the gas? :p
  13. Jul 31, 2012 at 7:57 PM
    2000GTacoma
    Snow Hill NC
    x2
  14. Jul 31, 2012 at 10:09 PM
    chilicoke
    Irvine, CA
    01 PreRunner DC
