[Help] Engine Turns over but wont start without Gas Pedal
Discussion in '1st Gen. Tacomas (1995-2004)' started by jake99x3, Jun 16, 2018.
  1. Jun 16, 2018 at 10:35 AM
    jake99x3
    jake99x3 [OP] Member
    Hey so i have this problem where my engine will turn over and not start unless I give it some gas. For whatever reason if I don't do the current starting procedure right the first time it's a lot harder to get it going afterwards. Once it's started up it runs great. After some reading I'm suspicious of the throttle body sticking at start or the fuel filter so I plan to replace/clean both of those later today/tmw morning. Any suggestions?
  2. Jun 16, 2018 at 10:38 AM
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    fully armored, 4.88, 33 skinnies, tundra brakes, a REAL cold air intake.
    Clean MAF?
  3. Jun 16, 2018 at 10:47 AM
    jake99x3
    Sensor looks clean but I guess it wouldn't hurt to clean it with the throttle body.
  4. Jun 16, 2018 at 12:07 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    How many miles are on it?
  5. Jun 16, 2018 at 12:54 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    IAC it controls the idle
  6. Jun 16, 2018 at 3:49 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Also what year and what engine?
  7. Jun 16, 2018 at 8:46 PM
    jake99x3
    158k, 1998, 3.4 5 speed 4wd
  8. Jun 16, 2018 at 8:47 PM
    jake99x3
    Cool I'll clean this tomorrow when I do the throttlebody, appreciate it.
  9. Jun 16, 2018 at 8:48 PM
    Sch0227
    Sch0227 Well-Known Member
    Steven
    Dallas, TX
    2017 TRD Parts bin
    Sharks with lasers
    If you prime the pump a few times and then it starts it's the fuel filter.. and honestly at 158k if you haven't changed it, it's probably due.. like 5 years ago
  10. Jun 16, 2018 at 8:57 PM
    jake99x3
    I guess test this by turning the key just enough to turn on the accessories, let it prime for a few seconds, repeat this a few times and then try to start it? Hoping to get this solved so I can take her out to the beach for the first time!! :) I already have the part and was going to do it tomorrow morning but it'd be cool to test it.
  11. Jun 17, 2018 at 1:14 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    The pump in our trucks doesn't turn on until the computer see's a signal from the camshaft turning. Cycling the key will do no good. Clean the throttle body and IAC first. Check the throttle shaft for excessive wear. A fuel filter change is always a good thing to do. It can't hurt.
    jake99x3[QUOTED][OP] likes this.
