Help figure out shock length
Discussion in '1st Gen. Tacomas (1995-2004)' started by presto, Apr 15, 2014.
  1. Apr 15, 2014 at 4:57 PM
    presto
    presto [OP] Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    So right now i have 5100's in the rear w/ dakar leafs and they are way too short. I was planning on getting Icon 2.0RR but just read in someones build that even those are too short for leafs that have 3" of lift. i was wondering if anyone knew where to find the collapsed length and fully extended length of icon shocks? i just want to measure and make sure before i order them.
    this is the one I'm trying to figure out collapsed/extended lengths for:
    http://toyteclifts.3dcartstores.com/ICON-95-04-Tacoma-Rear-Remote-Reservoir-Shocks_p_1052.html
    thanks
  2. Apr 15, 2014 at 5:32 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    I was hoping to order this tmrw so any feed back would be helpful.. I guess I could just try to call toytec or icon. That's probably what I'll end up doing..
  3. Apr 16, 2014 at 9:16 AM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    ok so called toytec and had them measure out the icon 2.0 RR and the fully extended length was about 24" and I'm looking for about 27" (my regular ride height is about 23" from eyelet to eyelet). I couldn't find anything else from icon that looked like it would work so I'm looking at King shocks now. They look very promising but they have so many damn options when ordering from their site and i don't know what to choose for some of them.
  4. Apr 16, 2014 at 9:19 AM
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    fully armored, 4.88, 33 skinnies, tundra brakes, a REAL cold air intake.
    contact Wheeler's Offroad, the bilstein 5125s can be custom length, I actually am having the SAME problem, on my 03, with Dakars. I will text a buddy of mine to try to get a part number
  5. Apr 16, 2014 at 9:28 AM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    id prefer not to get billys (nothing against them). I did see the custom length thing on wheelers with the 5125's but id prefer to get some kings or one of the "good" brands because I'm not paying for them haha..
  6. Apr 16, 2014 at 9:32 AM
    travis.diller
    Travis
    Kitsap Peninsula
    yea I agree, I want icons because thats what I have up front and they are awesome, I have a buddy that works at icon and he says that theirs are stock height. I haven't really looked into kings because as you said their site is overwhelming. let me know what you find!
  7. Apr 16, 2014 at 9:36 AM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    yep im so glad i do so much research because i was just about to order those icons too.. I looked at fox and i think its the same as icon they only do stock/1" lift height. i just need to make sure the eyelets will be the right size. i know ORI's have custom length too but those things are like 600 per shock lol.. So seems like King it is.
  8. Apr 16, 2014 at 10:01 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Take the guess work out of it. You need to cycle your suspension wih the shocks removed. Measure the distance between the top and bottom mount shock mounts and thats your exteneded and collapsed length.
  9. Apr 16, 2014 at 10:06 AM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    i know this. Im pretty good at playing the guessing game because I've messed with my rear suspension so damn much. i know it has a good few inches of down travel w/o my 5100's mounted and it sits at 22" ride height. the billys are 23ish fully extended and are way too short. 17" compressed and 27.5" extended sounds perfect to me.
    only thing is i need this bit of info to proceed with my order o_O:
    1.25" wide bushing(1/2" bolt)
    1.5" wide bushing (1/2" bolt)
    1.25" wide bushing (5/8" bolt)
    1.5" wide bushing (5/8" bolt)
    not sure how to find out the bushing/bolt size for the rear shocks?
    Edit: hmm I think I might have figured this out.. Still not 100% sure tho.
  10. Apr 16, 2014 at 11:00 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    You need to be sure though. When you get bigger shocks to accomodate down travel, you will lose up travel and if you dont adjust your bumpstop length to accomodate, you will run the risk of bottoming out your new shocks.
  11. Apr 16, 2014 at 12:15 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Already got bigger bump stops (timbrens). But I agree I should measure just to make sure. It just seems so close that if it needs minor adjustments I can do that when I have the shock in hand.
  12. Apr 16, 2014 at 1:10 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    After figuring out where to measure i think it is 1.5" wide and 5/8" bolt... thanks for all of the help guys..
