Help find the 3" lift for me
Discussion in 'Suspension' started by TacomaLove, Mar 17, 2010.
  1. Mar 17, 2010 at 10:35 PM
    TacomaLove
    TacomaLove [OP] Well-Known Member
    Brent
    Jacksonville
    06 PreRunner Access cab
    alpine m450 JL 3v3-4 10"
    hello TW! 1st timer here
    intro: With the help of Mom and pop i just bought my 06 tacoma 2 weeks ago and im absolutely in love a huge upgrade from my 91 cavalier! I now have the mod bug I have never been that big of a car/truck person so this is all completely new to me.
    the goods: I have an 06 tacoma access cab and ive put in a sub/amp (payed 60 for the install) and a toolbox is on its way i now am looking into powdercoating the rims, painting the badges black, BHLM and finally what brings me into the suspension section a Lift!
    I only have a budget of 500.00 (including alignment) at the very most more like 400. I have been researching around and the most popular choice seems to be the billy 5100s.
    Would 5100s in the front and AAL in the back be good?
    What would you guys recommend? I know it depends somewhat on the truck and im all very new to this.
    I dont plan to be doing off roading any time soon (maybe when the truck is older) i just love the lifted look.
    Thanks! and i look forward to learning and maybe one day contributing from TW.
    JBD
  2. Mar 18, 2010 at 6:55 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    There are other alternatives to 3" suspension lift like new coils from OME. I would save up more towards your goals so you will be happier in the end. It never ends because at 3" suspension lift, if you can't get your alignment back in spec you need new UCA's. Even some suggest UCA's with 2.5" max 5100's.
  3. Mar 18, 2010 at 10:29 AM
    TacomaLove
    Brent
    Jacksonville
    well i wouldnt want to do anything that would hurt the ride of my truck id be looking for a smoother ride hopefully.
    2.5inch would be fine 2 might be fine also i just want it to be noticeable that ive done something to my truck and something that will look/ride really nice
    Thanks for the help guys
  4. Mar 18, 2010 at 10:33 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Nothing will really make your ride smoother if you lift. If you want a solid 2.5-3" lift I would go OME.
  5. Mar 18, 2010 at 10:49 AM
    TacomaLove
    Brent
    Jacksonville
    a 1.75 inch lift would work as long as you guys think the differance is noticeable its hard to tell in some of the pictures and OME kit runs for around 700 from what ive seen id have to save up and im not really sure if i want a lift 800$ bad.
  6. Mar 18, 2010 at 12:30 PM
    sirsaechao
    Tim
    CA
    You will notice. Especially with a larger size tires.
  7. Mar 18, 2010 at 4:10 PM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    What about the new Fabtech 3"?
  8. Mar 18, 2010 at 6:34 PM
    TacomaLove
    Brent
    Jacksonville
    thats the thing i wont be able to buy tires for a good bit because my parents and they paid for 1/2 my truck...
    http://downsouthmotorsports.com/i-1...acoma-pre-runner-4wd-pre-load-adjustable.html
    Would this be a good setup overall?
    i could use the fronts at 2.5 or 1.75 and it would still be fairly level right?
    If i got this lift and kept my stock rims/tires would it look funny? Also im really new to all this i can put any size tire on my stock rims right? because i just think im going to powdercoat them black to save some money
    Thanks for the replys i really appreciate it
  9. Mar 19, 2010 at 12:20 PM
    TacomaLove
    Brent
    Jacksonville
    bump
    how do bumps work on here guys? just within reason? thanks
  10. Mar 19, 2010 at 12:22 PM
    sirsaechao
    Tim
    CA
    Lift it now and run the stock tires bald or buy them all at once. Eventually you will need tires. As far as funny looking. Who cares...it will be noticable that you added a lift but its not 6" so it should look more proportionate.
  11. Mar 19, 2010 at 3:49 PM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
  12. Mar 19, 2010 at 5:58 PM
    TacomaLove
    Brent
    Jacksonville
    kd8 i have read that spacers dont make for a good ride.
    so you guys think those billys and the AAL would work well? i have a 6 lug btw
    and i can put bigger tires on my stock rims right im new to this i dont want to have to trim the truck either...
  13. Mar 19, 2010 at 8:52 PM
    PreRunner
    PreRunner Well-Known Member
    for your budget id say the billies and AAL are definately your best bet.
  14. Mar 19, 2010 at 10:31 PM
    TacomaLove
    Brent
    Jacksonville
    would i be risking messing up the truck in anyway with this setup? like needing to get UCAs or anything? and will the ride be very similar?
    im just trying to understand what im getting into
    thanks guys and im open to suggestions
    and i can put bigger tires on my stock rims no problem right?
  15. Mar 19, 2010 at 10:34 PM
    sirsaechao
    Tim
    CA
    I suggest UCA's if you can't get your alignment in spec. Your stock wheels should be fine up to 33 x 12.50 but you need to run wheel spacers to clear the UCA's.
  16. Mar 20, 2010 at 12:02 AM
    TacomaLove
    Brent
    Jacksonville
    man thx for trying to help but i really dont understand the working of everything.. is there a good site that can explain to me how the suspension works and tires.. pretty much the whole truck.
    the allignment with a 1.75 lift shouldnt be difficult to get in spec without UCAs right? i dont really want to go to UCAs because of how expensive they seem to be and if i was going a route where they would be needed it would be better to save up and buy a toytec kit or something of that natue. Thanks
  17. Mar 20, 2010 at 12:20 AM
    Hunter423
    Hunter423 Hunter423
    hunter
    TN
    2008 Tacoma TRD off road
    brush guard, piaa foggs, tinted tail light, tinted windows, rain guards, pure white with blue tinted bulbd all over, white bulbs for licencess plate lighting, blacked out head lights
    my and my buddie installed a 3", 2" on my 08 taco and i didnt have to get new uca's or rear shocks even tho i did just install some new skyjacker nitro 8000 shocks
  18. Mar 20, 2010 at 9:03 AM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
  19. Mar 21, 2010 at 1:29 PM
    TacomaLove
    Brent
    Jacksonville
    yea UCAs are not what im looking for
    im starting to think that maybe billys with eibauch (something like this) springs in the front and just leaving the back or would you guys suggest a AAL or back billys also?
  20. Mar 21, 2010 at 1:45 PM
    tacoma gurl
    tacoma gurl Member
    jordan
    canada
    2010 trd sport
    i think before you do anything you need to go into the suspension and lifts section and read up......thats what i did....lots of good info
