Help finding Lock Motor Wire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lmvaughan, Oct 12, 2019.
  1. Oct 12, 2019 at 11:50 AM
    lmvaughan
    lmvaughan [OP] Well-Known Member
    Lewis
    G2 Toyota Tacoma
    White Toyota Tacoma/Cold Air/Interior Lights/Custom headlights/blacked out tailights/custom exhaust/lifted/custom wheels
    Hey everyone, trying to install a remote starter, I've gotten everything wired up except I can't find the lock motor wire anywhere. All i know is its blue/red and is in a 12 pin harness in spot 10. If anyone could help that be great!
  2. Oct 12, 2019 at 11:52 AM
    lmvaughan
    Lewis
    G2 Toyota Tacoma
    Also it's in the driver kick panel as well, I've looked through all the wires and found one blue/red wire however nothing happens when i tap it to ground so I assume its not the correct wire
  3. Oct 12, 2019 at 12:03 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    You don’t want to be sending ground to a motor wire. The lock wire is Blue/white pin 6 of the gray connector
    lmvaughan[OP] likes this.
  4. Oct 12, 2019 at 12:09 PM
    lmvaughan
    Lewis
    G2 Toyota Tacoma
    Awesome, thank you, according to the wiring diagram i was following, it said, "Touching this wire to ground (the set amount of times) can serve as a way to test the system. This wire connects to the vehicle drivers lock motor wire to detect the pulses generated by the vehicle door locks, that’s how pressing ‘lock’ on your OEM remote 3 times starts the car. Use your wiring chart to locate the “Driver Lock Motor” wire in the vehicle. Do not confuse the “Lock Motor” wire with the “lock switch” wire in your vehicle! Typically, the wire in the vehicle will be located at the drivers kick panel, or where the wires enter the vehicle from the door through the rubber boot. Testing the correct wire will show (-) ground when at rest, then when the lock button is pressed the wire will momentarily show (+) positive as the door lock is energizing, then return back to (-) ground where it will rest."
  5. Oct 12, 2019 at 12:14 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I was under the impression you needed it for locking. So yes that is the correct testing procedure. So if it’s just a sensing wire you’re hooking up to the motor wir, blue/red is the wire. It’s located in a white or black connector
    lmvaughan4 likes this.
  6. Oct 12, 2019 at 12:20 PM
    Muddinfun
    Muddinfun Well-Known Member
    You're on the right track now. The testing that the directions mention is grounding the remote start lock sensing wire to see if it starts. They are not meaning to ground the blue/red wire.
  7. Oct 12, 2019 at 12:22 PM
    lmvaughan4
    lmvaughan4 Member
    Lewis
    2014 Tacoma Prerunner white
    Okay thanks, I’ll keep looking I can’t find it for he life of me for some reason haha
  8. Oct 12, 2019 at 12:25 PM
    Muddinfun
    Also worth mentioning, once the engine is running, the key fob will no longer unlock the doors, so you will need to unlock the door with the key. The only work around that I know of is wire the remote start to the unlock so you push the unlock 3 times and it starts and is sitting there unlocked and running. No one can steal it but they can steal your sammiches out of the glovebox.
    TnShooter and lmvaughan4 like this.
  9. Oct 12, 2019 at 12:27 PM
    lmvaughan4
    lmvaughan4 Member
    Lewis
    Ah man that’s annoying , oh well I’ll probably just end up using the key
  10. Oct 12, 2019 at 12:30 PM
    lmvaughan4
    lmvaughan4 Member
    Lewis
    This is the one I found earlier but it didn’t seem to work, does it look right?
  11. Oct 12, 2019 at 12:49 PM
    Muddinfun
    It's against the TW rules to have more than 1 username.
    tcjacado likes this.
  12. Oct 13, 2019 at 12:03 PM
    lmvaughan4
    lmvaughan4 Member
    Lewis
    My bad, I think I made a different account on my phone a while ago since I couldn’t remember my password and needed to ask a question, I’ll delete the other one. Anyway I got it working!
    Tacogos and Muddinfun[QUOTED] like this.
  13. Dec 26, 2020 at 12:44 PM
    EliDills10
    EliDills10 New Member
    Eli
    Toyota 4Runner
    Where did you find this wire? I’ve ran into the same issue?
  14. Dec 26, 2020 at 1:38 PM
    lmvaughan
    Lewis
    G2 Toyota Tacoma
    So its in the driver side kick panel, from memory, once you take off the kick panel via unscrewing the hand screw you should be able to see a few different 12 pin connectors. You just have to look through all of them until you find a blue/red wire. There is only one. Once you find it, it should be in spot 10 of the 12 pin harness. But again that was the only blue/red wire I found in the driver side kick panel.
  15. Dec 26, 2020 at 6:59 PM
    SmokinTrails
    SmokinTrails New Member
    2018 TRD Sport 4x4
    Icon Stage 1 lift, icon progressive AAL, SPC uca,
    What year truck is this on? I'm about to install a remote system on a 2015 and the only wire they were ify about was the lock motor wire (for a relay on the remote start system) They tell me where it is kinda, but basically to test voltage at rest and when you lock the doors. So hopefully yours was a 2015 and I'm looking for a red/blue wire.
  16. Dec 27, 2020 at 7:53 AM
    lmvaughan
    Lewis
    G2 Toyota Tacoma
    It’s a 2014 but should be the same
  17. Dec 27, 2020 at 6:06 PM
    Tacogos
    Tacogos New Member
    2011 Tacoma TRD Off-road
    This page saved me. I just finished my remote start from MPC. I could not find my lock motor wire for my life. This is on the kick panel.
