Help finding some good rotors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TonyTDE, Jan 29, 2021.
  1. Jan 29, 2021 at 7:05 AM
    TonyTDE
    TonyTDE [OP] Member
    Tony
    2006 Tacoma TRD-Offroad
  2. Jan 29, 2021 at 7:11 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
  3. Jan 29, 2021 at 7:16 AM
    TonyTDE
    TonyTDE [OP] Member
    Tony
    Do you think the NAPA brand ones are any better than OE? The price from NAPA is pretty close to OE. I guess that is my other dilemma.
    pinktaco808 likes this.
  4. Jan 29, 2021 at 7:20 AM
    stevesnj
    OEM rotors are good. I've had good luck with NAPA rotors. Are you replacing OEM rotors?
  5. Jan 29, 2021 at 7:21 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    What is your definition of "good" rotors?
    I'd think NAPA, RockAuto or any auto store would have suitable rotors.
    These things are typically either a grey or ductile cast iron. Nothing fancy or exotic for everyday consumer rides.
    SR-71A likes this.
  6. Jan 29, 2021 at 7:23 AM
    TonyTDE
    TonyTDE [OP] Member
    Tony
    I am actually replacing a Stage 5 EBC kit. The pads wore super fast(25,000 miles), kinda disappointed in them. I would like something like OE or better like the StopTech's where they are a slight upgrade over OE.
  7. Jan 29, 2021 at 7:23 AM
    weeksz
    weeksz Well-Known Member
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    Try BrakePerformance.com I've been happy with their stuff. Made in USA, all coated, good prices, lots of options for performance and such. Lifetime Warranty.
  8. Jan 29, 2021 at 7:23 AM
    stevesnj
    Good as in quality.
  9. Jan 29, 2021 at 7:25 AM
    TonyTDE
    TonyTDE [OP] Member
    Tony
    Tacospike likes this.
  10. Jan 29, 2021 at 7:29 AM
    Knute
    Ok.....so what is good quality to you?
  11. Jan 29, 2021 at 7:31 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Im over 85k miles on my truck. 99% sure the OEM ones are still in there. (I bought it used around 40k miles)
    Never really understood all the hype about aftermarket brakes on these trucks :notsure:
    Accipiter13, eherlihy and TRDSport10 like this.
  12. Jan 29, 2021 at 7:35 AM
    Knute
    Agreed SR-71A.
    My '06 is sitting at 110 k miles, I've checked the brakes. They appear to have OEM rotors and pads with plenty of pad remaining. Just did a brake fluid change last October. Old fluid was a bit darker than the new, but not worth noting.
    TRDSport10 and SR-71A like this.
  13. Jan 29, 2021 at 7:38 AM
    TonyTDE
    TonyTDE [OP] Member
    Tony
    I'm running 285's so I thought a little extra braking power wouldn't be a bad thing...and I thought the EBC kit was going to be good. I have no problem with OE, I guess it's back to OE then lol
  14. Jan 29, 2021 at 7:47 AM
    dbbd1
    dbbd1 Well-Known Member
    I just bought the stoptech rotors and TRD pads. It took maybe two weeks to get the rotors.
  15. Jan 29, 2021 at 7:47 AM
    TonyTDE
    TonyTDE [OP] Member
    Tony
    Who did you order them through?
  16. Jan 29, 2021 at 7:51 AM
    Clearwater Bill
    Billy
    Largo Florida
    Once the brakes are locked / ABS kicks in the tires are what stops the vehicle. So for braking 'power', all you need is to be able to have a firm pedal that will actually lock up the rotors/drums.
    Bigger brakes are helpful if one has overheating issues. Those are typically caused by heavy tow (mostly downhill) or poor driving skills. 285s shouldn't be very eventful for braking system impacts.
    So did a lot of folks I autocrossed with. Didn't work out too well for them either. Like K&N, they have slick marketing.
    NAPA rotors are a good choice. The right pads, properly bled fresh fluid, maybe new lines and well serviced calipers/drums (everything cleaned/lubed to move freely) will make the most difference in feel.
    whatstcp and SR-71A like this.
  17. Jan 29, 2021 at 7:58 AM
    TonyTDE
    TonyTDE [OP] Member
    Tony
    Sounds like a lot of people are having good luck with NAPA. I will place an order for a set. I was also going to spring for some stainless braided lines from Headstrong and flush out the old fluids.
    stevesnj likes this.
  18. Jan 29, 2021 at 8:07 AM
    dbbd1
    I bought from buybrakes-dot-com.
  19. Jan 29, 2021 at 8:10 AM
    Clearwater Bill
    Billy
    Largo Florida
    Just remember the SS is the sheathing on the outside of a tube. It's only there for protection of the line carrying the fluid.
    That line is less susceptible to breakdown and expansion. Age softened rubber lines are normally what is being replaced, so the immediate feel is a stunning improvement.
    However, new OE lines can give a very similar result. You might want to do a price comparison and think about how long you plan to keep the vehicle?
    Nothing against the SS lines. I've used them and liked them. But they may, or may not, be a good $ choice in all situations.
    whatstcp likes this.
  20. Jan 29, 2021 at 8:13 AM
    dbbd1
    I thought that they S/S sheathing was to keep the rubber lines from expanding/swelling (thereby decreasing brake performance), much like my clothes washer water lines.
    ZColorado likes this.
