Help finding TDC on 3RZ-FE?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4banga, Oct 23, 2017.
  1. Oct 23, 2017 at 7:58 PM
    4banga
    4banga [OP] Semi-evolved monkey
    Colorado
    98 3RZ SC 4WD
    LCE headers & cat-back, Bilstein 5100s & AAL, LR UCA's, CVJ axles
    Hey everyone,
    I've been lurking these forums for a while and finally registered. What a fantastic resource this place is!
    I have a question that I have been trying to sort out. But before that I would like to state as a caveat that I am an amateur mechanic and I bought my truck ('98 Single cab 2.7l 4x4) with the intention of wrenching on it and learning along the way to get it into tip top shape. So far I've replaced LCA/UCA bushings, ball joints, added leafs in the rear and put on bilsteins, and just recently removed the old cracked cast iron exhaust manifold and replaced it with a newer mini header.
    Now I want to check my valve clearances. I took off the valve cover and I found the 19mm crank for the harmonic balancer pulley. My question is... how do I ensure that piston 1 is in TDC? Isn't there supposed to be a mark on the pulley? I know you can find TDC by taking the spark plug out but I would like to know the easier way of finding TDC.
    Any help/pictures would be greatly appreciated. Thanks.
  2. Oct 23, 2017 at 8:20 PM
    Glamisman
    Glamisman Well-Known Member
    here ya go
    • insp.pdf
      File size:
      392.5 KB
      123
    ak97taco, Dalandser and 4banga[OP] like this.
  3. Oct 23, 2017 at 8:22 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    There is a small notch on the pulley that lines up with the degree marks on the oil pump cover. It can be hard to notice unless you are looking for it. You can tell by the camshaft lobes when you are near TDC on cylinder 1, then look for the notch on the pulley.
    4banga[OP] likes this.
  4. Oct 23, 2017 at 8:33 PM
    4banga
    Colorado
    98 3RZ SC 4WD
    Thanks!!!
  5. Oct 23, 2017 at 8:43 PM
    4banga
    Colorado
    98 3RZ SC 4WD
    That document is super helpful. Is that part of a larger set of mechanical documents, and if so where could one find them? Cheers
  6. Oct 24, 2017 at 1:57 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    It's from the FSM - a complete one in paper is $100-$400 depending on condition and how lucky you get. Online / PDF manuals exist and if you can get a complete one, it's great. Mine is pretty weak - it's basically explosion diagrams w/ torque specs, but better than nothing.
  7. Oct 24, 2017 at 10:01 AM
    Glamisman
    the pdf FSM i.e. manuals are out there in the wild for free, you just have to track them down and download them. There is a "sticky" on the first gen forum, at the very top of the page and one of the postings is about FSM. Your truck is a 1998... the 2003 manual is good enough. Toyota has been making the motors in the first gen for so long and not much has changed mechanically from year to year... emmissions wise, thats a different story.
  8. Oct 24, 2017 at 11:24 AM
    4banga
    Colorado
    98 3RZ SC 4WD
    Thanks for all the input, y'all.
    I just checked my valve clearances and wow... my intake clearances ranged from 0.005 to 0.006 which is just below the range.... but my exhaust clearances are WAYY too tight.
    Most of my exhaust clearances were less than 0.004 (my smallest feeler gauge). I suspect this is because the truck was running with a cracked exhaust manifold for quite some time? What do you think? I know they're supposed to be 0.01 - 0.014.
    Anyways, I'm gonna invest in the shim adjustment tools and pull these shims out soon to measure them.
    Cheers
  9. Oct 24, 2017 at 2:09 PM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    How many miles on it?
    How can put 2 feeler gauges together to get more accurate measurements (if you haven't already). Like a 0.10mm + 0.01mm = 0.11mm. There is some error in each feeler gauge, but this is still a bit more accurate than just using 0.10, 0.125, 0.15mm, etc. (0.004, 0.005, 0.006 in). Although the specs give a range so you don't need to be too precise.
  10. Oct 24, 2017 at 2:48 PM
    4banga
    Colorado
    98 3RZ SC 4WD
    There are about 185,000 miles on it. I'm ordering some smaller feeler gauges (0.001 to 0.004 inches) and the valve tools.
    Kind of worried that the low exhaust clearances may be indicative of burnt valves... They're just so far off... Is this common?
    Cheers
  11. Oct 25, 2017 at 12:32 AM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    If you had burnt valves you'd know it. The compression would be low and it would be hard to start, especially if you had burnt valves in multiple cylinders. You'd have misfires at idle. You could do a compression test and leakdown test to check the condition of the valves and rings.
