Help ! First lift issues ome884 Bilstein 5100
Discussion in 'Suspension' started by Salsero144, Dec 16, 2018.
  1. Dec 16, 2018 at 5:42 PM
    Salsero144
    Salsero144 [OP] Member
    Joel
    2012 Tacoma Dbl cab long bed TRD SPORT
    i have a 2012 Tacoma Trd Sport DCLB. I had Monroe quick struts and had about 33 “ from fender to ground in front and 36” in rear. I was looking for approximately 2 inches of lift in the front. How ever after installing OME 884 and Bilstein 5100’s set at zero my front lift is now at approx 36 inches and rear just over 35”. Now the front is about an inch higher than the back. I now have a slight/minor super subtle vibration in the pedals. Everything else is stock.
  2. Dec 16, 2018 at 5:51 PM
    ClemsonMGM
    ClemsonMGM Even Firemen Need Heroes...
    Workin the pole!
    12 Ram 2500
    Make sure your spring perches look like a bell and not a bowl.
    If they are upside down (bowl), it could cause way to much lift.
    If you can take a picture of your struts that would help.
  3. Dec 16, 2018 at 5:52 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    ^this^
  4. Dec 16, 2018 at 5:53 PM
    hyper15125
    NJ (609)
    Have pics of setup??
  5. Dec 16, 2018 at 6:08 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    First guess is you put the bottom spring bucket pat on the shock upside down. Can you send a quick picture of it assembled strut?
  6. Dec 16, 2018 at 6:12 PM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    So you have 1" more lift on front then you wanted on brand new springs and no alignment and have given them zero miles to settle?
    And your freaking out?
    tcjacado likes this.
  7. Dec 16, 2018 at 7:58 PM
    Salsero144
    Joel
    I had the truck aligned right after and have put about 250 miles on the truck. I will Post a pic ASAP. The set up did come pre assembled from head strong off road.
  8. Dec 16, 2018 at 8:02 PM
    tcjacado
    tcjacado Well-Known Member
    Go to the mall and hit a few speed bumps. That will help them settle in.
  9. Dec 16, 2018 at 8:46 PM
    Salsero144
    Joel
    upload_2018-12-16_23-45-47.jpg Here’s one of the front
  10. Dec 16, 2018 at 8:47 PM
    Salsero144
    Joel
    Other view
  11. Dec 16, 2018 at 8:49 PM
    Salsero144
    Joel
  12. Dec 16, 2018 at 8:49 PM
    Salsero144
    Joel
    The perch appears like it was assembled correctly from headstrong
  13. Dec 16, 2018 at 8:50 PM
    tcjacado
    Looks ok. They may just need a little more time to settle in, but I doubt it will settle a inch. You may need to throw a 1 inch block in the rear to get it level or and extra leaf in the pack
  14. Dec 16, 2018 at 8:51 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Lift the rear, the springs may settle enough to where it is level. As for the vibration, check your driveline angles. If you’re 4wd, it sounds like you’ll need the ECGs bushing like the rest of us
  15. Dec 16, 2018 at 8:56 PM
    Salsero144
    Joel
    I was hoping to avoid messing with the rear. Just wanted approximate 2 inches.i knew I wouldn’t get exactly 2 but 3 seems way off. upload_2018-12-16_23-55-52.jpg upload_2018-12-16_23-56-23.jpg
  16. Dec 16, 2018 at 9:27 PM
    tcjacado
    Putting a 1 inch block in the rear is the easiest way. Its not a exact science lifting a truck. Each truck seems to be a tad different.
  17. Dec 16, 2018 at 9:46 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Just put an add a leaf in the rear.
  18. Dec 16, 2018 at 9:51 PM
    Salsero144
    Joel
    Is there any chance , when I went with the Monroe quick struts after the billstein4600’s (stock). The front end could have lowered to 33” from a higher position like 34”(possible being stock height )
  19. Dec 16, 2018 at 9:51 PM
    tcjacado
    Yes
  20. Dec 16, 2018 at 9:58 PM
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    Just drive it for 500 miles and see how much it settles.
