HELP fitting tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RyanBrooks7, Mar 4, 2013.
  1. Mar 4, 2013 at 5:11 PM
    RyanBrooks7
    RyanBrooks7 [OP] Member
    I got a set of 35's BFG on 17's. I want to put em on my taco. I have a 3inch suspension lift in the front and 2inch blocks in the back. I want to know if i add a 3inch body lift will the 35s' fit. 2008 4x4. Thank you
  2. Mar 5, 2013 at 7:41 PM
    BradyT88
    BradyT88 Well-Known Member
    With a 3" body lift I think the will fit just fine once you do the cab mount chop (part of the frame so a body lift won't help).
    Do you offroad much or just on road?
    I don't particularly recommend a 3" bodylift since I don't like the gaps and feel they are unsafe in the event of an accident. I am running a 1" bodylift to help clear tires with my 3" lift. After that it is just lots of trimming of the fenders and flairs. If you don't offroad shouldn't take much trimming at all.
    Oh and Welcome to TW:D
  3. Mar 5, 2013 at 7:43 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Cab mount chop for sure.
    Don't do the BL if you plan on wheeling it unless you don't mind fall-apart.:(
